steering column
Old Oct 7, 2011 | 11:16 PM
smoke n tires's Avatar
smoke n tires
steering column
hello everyone. im having a problem with the steering column on my 68 f100. i had some crackling in the bottom of the column and now i have ball bearings falling out on the frame from the lower column bearing. is there a repair or replacment bearing i can install?
Old Oct 8, 2011 | 03:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by smoke n tires
I'm having a problem with the steering column on my 68 f100. i had some crackling in the bottom of the column and now i have ball bearings falling out on the frame from the lower column bearing. is there a repair or replacment bearing i can install?
Since you didn't say, I assuming your truck is 2WD
C3DZ-3517-A .. Steering Column Bearing / Available from Ford.
Applications: 1961/70 F100/250 4WD upper / 1961/73 F100/250 2WD upper/lower / 1966/74 Bronco upper/lower / 1967/73 F350 upper/lower / Myriad 1960's Passenger Cars.
MSRP: $10.68 // FTE sponsor PARTSGUYED.COM price: $7.69
Old Oct 8, 2011 | 06:50 PM
smoke n tires
thank you for the info. is this something the column has to be removed for or can it be installed from the bottom side in the truck?
Old Oct 8, 2011 | 09:45 PM
orich's Avatar
orich
If yours has the fixed flange at the bottom that bolts the the rag joint yes the tube has to be removed. But the lower tube itself may need a new bearing cup welded into it. I believe you can just remove the steering wheel and dash mounting bolts, blinker wires and clamp by fire wall that holds the tube. I may have forgot or missed some little things to loosen but it is the main stuff. hope this helps some..my 2cents
orich
lauxg
Jan 9, 2020 07:51 AM
Mercmeister
15
Jan 29, 2015 01:35 PM
abe
Nov 1, 2013 09:07 AM
vwfreak
17
Aug 7, 2012 10:36 AM
dj8667
May 4, 2005 10:16 PM
