Zerk in steering column
Old Oct 30, 2013 | 07:06 PM
abe's Avatar
abe
My steering column has been making some weird noises (creaking) and it has some spots where it seems to jerk, like it has passed a tight spot when I make a turn. Is there a grease fitting on the column somewhere?
It is my 70 F350 with power steering.
thanks!
Old Oct 30, 2013 | 07:43 PM
JEFFFAFA's Avatar
JEFFFAFA
Nope. Just pre-greased upper and lower bearings. It's probably just the upper bearing that needs to be re-greased or replaced.
Old Oct 30, 2013 | 08:25 PM
abe's Avatar
abe
What would I need to do to regrease it? About how much if I had to replace?
Old Oct 30, 2013 | 08:52 PM
FECruzer69's Avatar
FECruzer69
I believe the proper fix for the upper bearing is to just replace it. They cost around $15 - $20, I think.
On my old column the lower bearing was making grinding noises. When I removed my column I found that it (the lower bearing) had basically disintegrated.
Old Oct 30, 2013 | 10:13 PM
crazed87bronco's Avatar
crazed87bronco
I rebuilt my steering column in my 71 with all new bearings and retainers only takes a couple hours to do hardest part is getting the column out of the truck. Your column should have the same upper and lower bearings if I remember right. Try going to your local ford dealer and they might be able to get or have them for you. I tried getting mine at the dealer but they weren't much help even with the part numbers I gave them. But others on this site had no problems getting what they needed at there dealer.
Old Oct 31, 2013 | 09:25 AM
abe's Avatar
abe
I don't know if it matters bit my 70 has a steering column from a 71....
Probably no difference except the different steering wheel....
Old Oct 31, 2013 | 07:04 PM
JEFFFAFA's Avatar
JEFFFAFA
Same,same. From memory the part number is C3DZ3517A. UPPER and LOWER. Still available from Ford. If you were closer I'd offer to sell them to ya.
Old Oct 31, 2013 | 07:15 PM
Corkwheats's Avatar
Corkwheats
Thanks for posting this. I have a 78 Bronco Tilt Steering Column in my 71 F100 Truck. I noticed a little "popping" as I turned, and thought it may be the bearings starting to go.
I wish there were a person on here that did Steering Column rebuilds. I don't have the experience or the time.
Bob
Old Oct 31, 2013 | 07:20 PM
JEFFFAFA's Avatar
JEFFFAFA
Bob
78's had different bearings. I've never done one but from selling parts to them all these years I think they are a piece o' cake to take apart.
Old Oct 31, 2013 | 07:31 PM
MIKES 68 F100's Avatar
MIKES 68 F100
get some white Lithium grease in a spray can , comes out liquid then tuns to grease. put a red tube on it and squirt down inside column , works great been doing this for years to my old Mustangs .
Old Nov 1, 2013 | 06:27 AM
Corkwheats's Avatar
Corkwheats
Great Tip! Thanks! And, this can be done without removing the steering column, I'm guessing. Don't mean to sound dumb, but my truck isn't here right now, or I'd go look (It's at a friend's place getting a Super Bad 390 installed).
Bob
Old Nov 1, 2013 | 09:07 AM
MIKES 68 F100
You should remove the steering wheel , but column can stay in place
mercman68
May 12, 2007 08:01 PM
dj8667
May 4, 2005 10:16 PM
badboyina67
Jul 5, 2002 04:52 AM
