? For number dummy
Old Oct 7, 2011 | 10:40 PM
zukinut's Avatar
zukinut
? For number dummy
Can the disc brake proportioning valve for a 68 f350 be purchased new?
Thanks in advance
Will
Old Oct 8, 2011 | 03:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by zukinut
Can the disc brake proportioning valve for a 68 F350 be purchased new?
C8TZ-2B257-G .. Brake Differential Proportioning Valve / Obsolete
Applications: 1968/72 F250 2WD & F350 w/optional dual piston caliper disc brakes / 1973 F250 2WD w/dual piston caliper disc brakes / 1973 F350.
No Ford Dealer or obsolete parts vendor has any.
Old Oct 8, 2011 | 04:23 AM
zukinut's Avatar
zukinut
Any suggestions on where to find one? Is it by chance the same as a f100?
Thanks again
Will
Old Oct 10, 2011 | 10:33 AM
zukinut's Avatar
zukinut
Number dummy, if it's obsolete from ford can it be purchased aftermarket? Will one from a f100 work? There are plenty of f100s to be had at the Local pull a part.
Thanks in advance
Wil
Old Oct 11, 2011 | 04:28 AM
NumberDummy
I have no idea if it can be purchased from the aftermarket sector...it prolly won't be listed under the Ford part number if it is.
This valve is specific to 1968/72 F250 2WD & 1973 F250 2WD, all w/dual piston caliper disc brakes and 1968/73 F350's.
What's wrong with your valve?
Old Oct 11, 2011 | 04:47 AM
The Masked Rider's Avatar
The Masked Rider
If ha got an automatic, bolt on one of these guys under the dash. They are great for hole shots. Allows those rear wheels to spool up before ya lanch it They work great and have different settings.
Poly Performance JEEP/TRUCK & BUGGY*::*Brakes & Controls*::*Proportioning Valves*::*Wilwood Lever Proportioning Valve - 4X4 Off-Road Parts, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Brakes, Johnny Joints®, Currie Enterprises, Edelbro
Tex51
Apr 25, 2019 08:14 PM
cjbronco
Sep 12, 2018 10:05 AM
Ron_Hall
Sep 7, 2018 06:59 AM
Tom the novice
Oct 18, 2014 09:03 AM
Blackwaterforge
May 1, 2009 07:51 AM
