proportioning valve
Old Apr 28, 2009 | 08:53 AM
Blackwaterforge's Avatar
Blackwaterforge
proportioning valve
Are proportioning valves still available new? I need one for a 66 F250 Camper Special that I am adding disc brakes from a 73 F250 with dual piston calipers.
Thank You!
Old Apr 29, 2009 | 03:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thank You!
1973 (1974/79 is different) F250 2WD dual piston calipers w/a 6900, 7500, or 8100 lb. GVW:
C8TZ2B257G .. Brake Differential Proportioning Valve / Obsolete
Also fits: 1968/72 F250 2WD with disc brakes / 1968/73 F350 with disc brakes.
PEROGIE ENTERPRISES in Highstown NJ has ONE: 609-448-1684.
No Ford Dealer, or other obsolete parts vendor has any.
btw: 1973 F250 2WD's with a 6200 GVW have single piston calipers.
Old Apr 29, 2009 | 07:23 AM
Blackwaterforge
Thanks ND! Dose the proportioning valve have built in residuals?
Thank You!
Old Apr 30, 2009 | 02:01 PM
Blackwaterforge
Hi ND
Perogie said I had the wrong phone #
Old Apr 30, 2009 | 07:33 PM
drof46's Avatar
drof46
check e-bay for an aftermarket
Old Apr 30, 2009 | 09:14 PM
flipklos's Avatar
flipklos
I bought a screw type for $35. Works great. I can with the flick of the wrist stiffen my rears for towing on my 85. OE replacement was $200. Whole deal with all new hardlines front to rear was about $80. $25 was adapters. They aint cheep.
Anyone know of a good source of brake line clips for attaching to the frame? SHe wont fall apart but I dont want rubbing.
Old Apr 30, 2009 | 10:17 PM
drof46's Avatar
drof46
Couldn't find original so I bought plastic clips on ebay. used existing hole and bolted them on. Guy sells them for $5 per bag with assorted sizes.
Old Apr 30, 2009 | 10:29 PM
flipklos's Avatar
flipklos
Just type in "brake line clips"?
Old May 1, 2009 | 04:49 AM
NumberDummy
Hi ND
The phone number I listed is what is shown on the obsolete search website: PartsVoice.com.
If it's wrong, that's not my fault.
Old May 1, 2009 | 07:51 AM
Blackwaterforge
You are right ND. It's also the # listed on web-site I called twice. The second time the guy was rude. I sent e-mail. Thanks for all your help!
PAwhiteboy
Nov 3, 2012 11:31 PM
1973F100Kid
Dec 4, 2011 07:02 PM
mhopkins
18
Apr 9, 2009 07:54 PM
78super4x
May 3, 2007 10:24 PM
phoneman91
Apr 21, 2005 01:49 AM
