03 6 liter problems
Old Oct 7, 2011 | 03:48 AM
powerstroke72's Avatar
powerstroke72
Welcome to FTE.
I've moved your thread to the 6.0L Powerstroke Diesel forum.
Old Oct 7, 2011 | 05:58 AM
npccpartsman's Avatar
npccpartsman
Sounds like your #6 injector needs replacing. Is it cranky running/driving until it gets warmed up?
Old Oct 7, 2011 | 06:27 AM
npccpartsman
Originally Posted by big blue oval
Nope, used a FRAM....but I have used those before..?
The Fram filter is fine (in this case). Absolutely NO NEED to change it early.
big blue oval's Avatar
big blue oval
Yes, it is.........
Old Oct 7, 2011 | 06:31 AM
npccpartsman
Yes, it is.........
I noticed you have two threads going on the same thing and I'll try to get them merged together.
FWIW--the Fram filter is fine. Don't waste your time changing it. IMHO it sounds like you're suffering from some pretty serious injector stiction. You might also want to do the FICM diagnostic procedure. At 250K miles, like Cheezit said, you could have several issues causing a contribution balance code.
Old Oct 7, 2011 | 07:06 AM
Maxium4x4's Avatar
Maxium4x4
Done.... Thanks Tim, we now have one thread.
Old Oct 8, 2011 | 07:11 AM
big blue oval
I just noticed (duh) that the glow plug symbol isn't coming on on the dash. What is the procedure to check them? Is that info available online anywhere?
THANKS
Robbie
Old Oct 8, 2011 | 07:28 AM
npccpartsman
THANKS
Robbie
The best way is to code scan the truck. It will tell you if you have some kind of fault in the GPCM. It may take something more advanced to diagnose faults in the Hybrid Electric Cluster (dash).
redbeard_actual
19
Apr 24, 2019 09:16 AM
spindler52
Nov 29, 2011 11:59 AM
RKR
Nov 26, 2011 09:41 AM
88PONY
13
Apr 3, 2011 11:27 AM
desertt5
Mar 19, 2011 10:30 AM
