03 6 liter problems
Old 10-07-2011, 03:48 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Welcome to FTE.
I've moved your thread to the 6.0L Powerstroke Diesel forum.
Old 10-07-2011, 05:58 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Sounds like your #6 injector needs replacing. Is it cranky running/driving until it gets warmed up?
Old 10-07-2011, 06:27 AM
npccpartsman
Originally Posted by big blue oval
Nope, used a FRAM....but I have used those before..?
The Fram filter is fine (in this case). Absolutely NO NEED to change it early.
big blue oval's Avatar
big blue oval
big blue oval is offline
Yes, it is.........
Old 10-07-2011, 06:31 AM
npccpartsman
Yes, it is.........
I noticed you have two threads going on the same thing and I'll try to get them merged together.
FWIW--the Fram filter is fine. Don't waste your time changing it. IMHO it sounds like you're suffering from some pretty serious injector stiction. You might also want to do the FICM diagnostic procedure. At 250K miles, like Cheezit said, you could have several issues causing a contribution balance code.
Old 10-07-2011, 07:06 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,484 Likes on 2,141 Posts
Done.... Thanks Tim, we now have one thread.
Old 10-08-2011, 07:11 AM
big blue oval
I just noticed (duh) that the glow plug symbol isn't coming on on the dash. What is the procedure to check them? Is that info available online anywhere?
THANKS
Robbie
Old 10-08-2011, 07:28 AM
npccpartsman
THANKS
Robbie
The best way is to code scan the truck. It will tell you if you have some kind of fault in the GPCM. It may take something more advanced to diagnose faults in the Hybrid Electric Cluster (dash).
redbeard_actual
19
04-24-2019 09:16 AM
spindler52
11-29-2011 11:59 AM
RKR
1997-2006 Expedition & Navigator
11-26-2011 09:41 AM
88PONY
13
04-03-2011 11:27 AM
desertt5
03-19-2011 10:30 AM
Quick Reply: 03 6 liter problems
