03 6 liter problems
Old Oct 6, 2011 | 08:59 PM
big blue oval's Avatar
big blue oval
03 6 liter problems
New guy here! Thanks for such a great site. I have searched around looking for an answer to my questions, but haven't really found what I was looking for. I'm sure my question is common, but i'm curious as to what you may be able to tell me.
2003 6.0 F250
249,000 miles. Truck has never had a programmer on it. Never had a seconds problem till 200,000. I had the latest updates installed in the computer after it became hard to crank at 200. Since then, the truck skips pretty good at idle, but runs good once you get above idle. It is becoming increasingly harder to crank...spins great, but is slow to catch and idle. I had it hooked to a scanner and it says my #6 injector isn't contributing. Could this be causing the slow start also? could the IPR be causing that? I changed the ICP a few months ago, because it was leaking horribly. Any ideas?
Thanks in advance,
Robbie
Old Oct 6, 2011 | 09:27 PM
cheezit's Avatar
cheezit
at 250k theres alot that it could be. have you check to varify glowplugs are working. relitive compression, excessive blowby are all things that can cause this.
its possibel one injector is making things hard but I woudl suspect more is involved.
Old Oct 6, 2011 | 09:41 PM
BLADE35's Avatar
BLADE35
Im betting the answer to yoour problem is in the #6 contributation code you got
Either a Bad injector#6 or a bad injector wire harness
further down the possibles list would be the Ficm issue
a compression test would verify that its not majoir issue on #6
Fix the code then go from there
Old Oct 6, 2011 | 09:42 PM
big blue oval
Thanks for the reply....I haven't verified the glow plugs...I'm in South Ga and it's pretty warm. Could that still be a factor?
Old Oct 6, 2011 | 09:43 PM
big blue oval
Benny, thanks for the reply...I'm gonna change the injector ASAP and see how it goes....
Thanks again
Old Oct 6, 2011 | 09:45 PM
cheezit's Avatar
cheezit
it could be on an engine with some wear. easy to check with a volt meter. there is a 4 wire connector for each buss bar. just need to check them there.
Old Oct 6, 2011 | 09:48 PM
big blue oval
Are you looking for voltage when the truck is switched on?
Old Oct 6, 2011 | 09:49 PM
BLADE35's Avatar
BLADE35
Might want to check that injector harness first Load test with a high beam lamp and for continuity
I hear 03 harness sucks been waiting for mine to cause me greif
but with that kinda miles could be an injector too IDK
good luck keep us posted
Old Oct 6, 2011 | 09:50 PM
big blue oval
Will do..THANKS for the willingness to help.....one more wierd note...changed my oil today, used Rotella T6 synthetic for the first time.....truck runs worse than ever......
Old Oct 6, 2011 | 10:00 PM
BLADE35's Avatar
BLADE35
Did you use a motocraft oil filter
some of the AM will fit filters are to short and cause problems
Old Oct 6, 2011 | 10:03 PM
big blue oval
Nope, used a FRAM....but I have used those before..?
Old Oct 6, 2011 | 10:07 PM
Unrealo4's Avatar
Unrealo4
Non oem filters can cause a no start. Running bad I'm sure is on the list as well.
Old Oct 6, 2011 | 10:10 PM
big blue oval
Thanks UNREAL...Ill change the filter tommorrow..Anyone see a problem with the Rotella?
Old Oct 6, 2011 | 10:39 PM
BobsF350's Avatar
BobsF350
Its not the filter
Old Oct 6, 2011 | 10:50 PM
big blue oval
Thanks for the reply Bob. It could be a big coincedence, but the truck runs horrible since the oil change.....
