ICP and uvhc
Old Oct 5, 2011 | 10:52 PM
Bstevens's Avatar
Bstevens
ICP and uvhc
New to site been looking in on some answers. Got a 99 350 7.3 powerstroke rough idle and dieing and refiring in flight. got a p1280 Icp failure on my edge. I saw a thread that talked about the UVHC can anybody tell me what that is and where on my engine thats located?
Old Oct 5, 2011 | 10:55 PM
snakedoc's Avatar
snakedoc
it is the under valve harness connection. this is the .50 thread will show you how to fix it.
https://www.ford-trucks.com/forums/9...-cent-mod.html
here is the icp, you can unplug the icp then start it and if fixes it then that might be it.
Old Oct 5, 2011 | 11:02 PM
mueckster's Avatar
mueckster
Under Valve Cover Harness
It is the wiring that connects to the injectors and glow plugs.
The P1280 can be caused by a faulty ICP sensor or oil in it's connection. Either way, the sensor would need to be replaced. You can unplug the sensor while it is idling rough and the PCM should go to a default setting and smooth out. This would indicate a bad ICP sensor.
Edit: Matt got you covered!
Old Oct 5, 2011 | 11:06 PM
Bstevens's Avatar
Bstevens
thanks for the info got a weekend project now.
Old Oct 5, 2011 | 11:08 PM
Bstevens's Avatar
Bstevens
That and a fuel leak drivers side top of motor should keep me busy.
ofullard
22
Jun 22, 2017 11:16 AM
imnotcommon
Oct 10, 2013 07:29 AM
03superdoody
Sep 8, 2009 08:40 AM
strange
Jan 27, 2007 07:51 PM
puffer
17
Dec 17, 2005 11:43 AM
