High idle right at startup...
Old Oct 4, 2011 | 03:09 PM
Peach Grower's Avatar
Peach Grower
I have a 1989 f150 300, 5spd, 140000miles, 2WD....same truck I'm having the missing at startup issue. Its always done this though. When I start it revs pretty high...I'd say 1500 or so then settles down..I HATE starting engines fast on cold mornings. I've heard ALOT of Fords do this. It idles find after it revs back down. Is there a way around this?? It does it nearly everytime...not everytime but close. Way higher than I'd like. Settles back down after only a few seconds. What causes this?? I've cleaned the IAC very well and no vacuum leaks. If I unplug the IAC it idles WAY down....probably to 500 or a little lower. But is still smooth. What causes the initial high idle?? I wish I could keep if from doing that...That reving up when its 50 degrees and lower scares me. Thanks again guy! Any information would be appreciated. Full tune up done also and cleaning of throttle body and IAC in last few weeks.
Old Oct 4, 2011 | 03:24 PM
TheWhiteBeast's Avatar
TheWhiteBeast
It's a normal function of a ford engine, they all do it. No need to be scared, be more concerned that you are using a good oil! In my mind it is like fuel enrichment in a jet engine. It does this until the combustion cycle stabilizes to prevent the motor from dying on start up.
Old Oct 4, 2011 | 03:27 PM
jas88's Avatar
jas88
My 300 did this everytime I started it whether it was hot or cold. I never did find out what caused it and it was annoying. I would expect it to idle high when cold and then drop to normal, but it shouldn't do it when the engine is warm.
The 460 I put in it's place doesn't do it at all, even when it's cold. I like it that way much better.
Old Oct 4, 2011 | 04:03 PM
Peach Grower
yeah I understand the high idle...just like the kick up on carbs and high idle lever on boat motors...but I'd rather it die a couple times that rev up when I start it...normally when warm its not nearly as high...Just doesn't seem like a good deal when cold. I run mystic 15w40 synthetic in my 300. Guess its more annoying than anything.
Old Oct 4, 2011 | 05:16 PM
TheWhiteBeast
I don't think you can go wrong with the Mystic but if you are worried about cold starts I would take it down to a 10w30 and use a Motorcraft filter for the anti-flowback valve. Right now you're running diesel oil, which by the way works wonders in the old IH 347.
akorcovelos
Nov 3, 2010 10:30 AM
tdister
1997 - 2003 F150
May 14, 2007 06:08 PM
dhelm72
Sep 9, 2005 12:50 AM
jetman4
Dec 29, 2003 11:45 AM
nhf72003
Nov 23, 2002 07:19 PM
