trans question
Old Oct 4, 2011 | 06:54 AM
Eastland's Avatar
Eastland
trans question
So if the vehicle shifts smoothly but sometimes is rough moving the shifter into park and seems to have a little more roll once it is placed in park is this a sign of a transmission going bad or just how that one works. If its a sign then what can be done to fix/extend the trans? I noticed on the Ex I test drove that it was a little tough going into park but I have had a similar experience with the 2001 escape that I am currently driving though it does not happen much unless I am parked on a hill. Any input would be appreciated.
thanks,
Old Oct 4, 2011 | 06:58 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Here, try this link....https://www.ford-trucks.com/forums/1...ml#post9469302
It could be the cause for your hard shifting into park, as far as the rolling I don't think so.
Old Oct 4, 2011 | 02:48 PM
Eastland's Avatar
Eastland
Thanks for link and from what I read it sounds like that may be what was going on with the ex I test drove. I know that you get roll after you put an auto trans in park but does how much it moves any indicator of the state of the trans? On the escape I recently parked on a rather steep driveway and got the normal bit of roll back after letting off the brake but was kind of hard to shift back into reverse when i went to leave, is this normal or bad?
thanks,
Old Oct 4, 2011 | 05:14 PM
sddesigns's Avatar
sddesigns
FTE Emeritus
thanks,
on a steep grade you should set the parking brake/emergency brake, there is a little fork that holds the trans in park it will set itself on the fork and put a lot of pressure on it, that is why it's so hard to get it back out of park, so remember set the parking brake when on a steep incline.
ReBilld
Jan 31, 2013 09:19 PM
mr.auto
Nov 19, 2010 05:38 PM
kenpobuck
15
Jul 11, 2010 04:38 PM
Hillbilly Rockstar
May 5, 2010 07:51 AM
73F100*8Mile
Dec 30, 2007 10:40 PM
