Interior lights staying on
Old Oct 3, 2011 | 06:50 AM
rbrad6937's Avatar
rbrad6937
2000 X V-10 4X4.
My interior and running board lights are staying on all the time and I had to pull the fuse. I have tried the WD-40 trick but it is not working this time as it has done in the past. I have also checked the dimmer switch to make sure it was not on all the time. Is there an easy way to find out which door lock actuator is causing this, or do I have to replace all of them? What is the best way to approach the troubleshooting of this?
Thanks,
Robert
Old Oct 3, 2011 | 07:23 AM
1BigBo's Avatar
1BigBo
When mine did the same thing i found there is a relay in the insterment cluster that goes bad. I had to replace the whole cluster to get the lights to work properly.
Old Oct 3, 2011 | 07:51 AM
jh818's Avatar
jh818
It would not be the actuator. It's the switch in the door jam. Not sure of an easy way to isolate the culprit.
Does the light go off eventually after some time?
Old Oct 3, 2011 | 08:15 AM
rbrad6937's Avatar
rbrad6937
No, the lights stay on all the time
Old Oct 3, 2011 | 08:20 AM
jh818's Avatar
jh818
It's probably that relay 1BigBo mentioned.
Old Oct 3, 2011 | 08:28 AM
rbrad6937's Avatar
rbrad6937
Do you know where this relay is located?
Old Oct 3, 2011 | 11:13 AM
Fishing_Uncle's Avatar
Fishing_Uncle
Sounds like what happened to me when I first got my X. I noticed that my door ajar light was on also so I assumed it was a stuck door switch. I ended up re-opening and closing all the doors / hatches one at a time with a little more force than normal and noted which one actually turned off the lights.
Is your door ajar light on as well?
Old Oct 5, 2011 | 05:33 AM
1BigBo's Avatar
1BigBo
The relay is built into the custer main insterment circuit board. as far as I now there is no way to test it to see what part is bad. I bought a used cluster from the junk yard and took it to a local spedo shop and had the milage reprogamed into the junk yard one all is good.
Old Oct 5, 2011 | 06:25 AM
rbrad6937's Avatar
rbrad6937
Thank you for the reply. I checked and a used instrument cluster costs about $150.00. I want to be completly sure this is the problem before I spend this amount of money. Can amyone else chime in on what the problem and fix may be? I have removed the fuse to keep the lights off but I have lost my mirror adjustment and power windows. I dont mind spending the money if I know what the fix is.
Thanks,
Robert
Old Oct 6, 2011 | 05:50 AM
rbrad6937's Avatar
rbrad6937
Anyone ????????
gunnar01
Jul 9, 2015 10:15 PM
superduty2001
Feb 22, 2015 08:49 AM
AzSuperDuty
Nov 16, 2014 05:39 PM
7.3 Ex
Mar 4, 2011 11:59 AM
Big-Red-Lariat
2004 - 2008 F150
Feb 21, 2009 02:07 PM
