Shutter at 45-50
Old Oct 2, 2011 | 09:38 PM
ZChavira's Avatar
ZChavira
Shutter at 45-50
I have an '04 F-150 Lariat with 103K it has a slight vibration in between 45-50 and seems like it bogs down in O\D, when you turn O\D off the problem stops, took it to the ford dealer and they said to put Shutter Guard in it to see if it helps, it seems to still be doing it? Any ideas?
Old Oct 3, 2011 | 05:28 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome to FTE! I've provided you with a link to the proper forum: 2004 - 2008 F150 - Ford Truck Enthusiasts Forums. These folks will likely have a better idea of what your're dealing with.
As a recommendation, when you re-post provide as much information about your truck as possible such as engine size, which transmission, 4x4 / 4x2 and any mods that you may have added to the truck such as performance chips, lift kits, larger tires, etc.
Good lick!
Old Oct 4, 2011 | 11:00 PM
jimmyb08SD's Avatar
jimmyb08SD
My 04 STX 4X4 developed a very mild shudder at approx 40 - 50 mph and then over a few weeks it got worse, to the point it felt like the truck was bouncing hard enough to loose traction. Just by chance the next time it did it I reached down and held the e- brake release and slightly pushed on the pedal which immediately changed it, almost went away. Took it in, dealer cleaned and lubed parts in the e-brake assembly and all was well. Due to road salt, rust, etc. the e-brake was not releasing all the way. Something to consider.
ZChavira
2004 - 2008 F150
Oct 5, 2011 09:33 PM
Swatnducks
2004 - 2008 F150
29
Oct 21, 2005 10:44 AM
srq
2004 - 2008 F150
Mar 11, 2005 02:11 PM
Garycas
2004 - 2008 F150
Jan 16, 2005 11:25 AM
dampam6535
2004 - 2008 F150
Jan 28, 2004 09:04 PM
