Intermittent Vibration
Old Mar 10, 2005 | 11:59 AM
srq's Avatar
srq
Can anybody help me explain this problem, I will be making an appt with the dealer very soon but I wanted to have little more information before I do it,
The last couple of weeks my 04 screw with just under 10k mile has started to vibrate very bad only for a few miles then stop, its only happened 3 times, its been so bad that the hood shakes, for example I was running around yesterday made a quick stop, got back in my truck noticed a little vibe at about 20mph, got on the freeway took to about 60 mph, now its shaking really bad put into neutral coasted a bit, no change in the vibration, tapped the emergency brake and released it to see if that was hung up, it got worse, I coasted off an exit, came to a stop, light turned green, vibration gone, while I was slowing down it felt as if something was dragging me to stop, anybody experince this?, by the way I do get the clunk and shudder at times, but not enough to bother the dealer with it yet
Thanks for any input
Old Mar 11, 2005 | 01:55 PM
Sean Kennedy's Avatar
Sean Kennedy
There was a post from someone who was having their parking brake drag which resulted in his vibrations. He said the dealer fixed it by drilling out the hole where the parking brake cable goes throught backing plate of the drum portion of the rear break. I guess the hole was too small and it prevented the parking brake from completely releasing. I had a vibration problem, but mine was caused from a dirt build up on the rims throwing my tires out of balance. I pressure washed them off getting all the built up dirt out of the rims and it went away. These trucks are very sensitive to how the tires are balanced. I would also make sure you rotate the tires every 6000 miles. Just my thoughts.
Old Mar 11, 2005 | 02:11 PM
SilverSC's Avatar
SilverSC
SRQ,
Nobody really knows what is going on. The problem that you are describing is SO widespread. Regarding the shudder or vibration on take off or turning. You may want to talk with your service mgr about having the clutch packs replaced in the rear diff. I bought a 04 Screw in December, regretting it since then. Shakes, shudders, vibrates. I have had the truck in for service work five times, only 3900 miles on the beast. Two weeks ago they replaced the clutch packs which did help the shuddering on take offs & turning. To say the least, I am extremely disappointed with the truck & Ford. My truck will vibrate bad enough that you can feel it in the floor boards, pedals, seat, steering wheel, rear view mirror gets blurred, bed visibly shakes, AND because of all of this, the rubber seal/gasket around my rear window now chatters like a monkey on crack. It is to the point that I hate to get in the truck & drive it. I am getting ready to start proceedings to have Ford buy the truck back. The service mgr at my dealership just told me this morning that Ford is scratching their heads, trying to sort this mess out. It is a hugh, widespread problem. They do not know how to fix it yet. Good luck!
mclarengts
May 20, 2016 02:23 PM
Kjones22
2009 - 2014 F150
Jun 23, 2015 07:54 PM
MikeRizz
Aug 26, 2013 08:11 PM
bigfishford
Feb 22, 2006 08:09 PM
dumontkid
May 6, 2003 07:30 PM
