Power steering questions
Oct 2, 2011 | 07:45 PM
Will the ps shaft and box from a 73-79 f100 work on a 68 f350 Ive found a bunch of 100s but very few 350s.
Thanks in advance
Will
Oct 3, 2011 | 06:55 PM
Oct 3, 2011 | 08:22 PM
If the 350 is a 4 wheel truck it should work, the duallys may be different.
John
Oct 4, 2011 | 06:54 AM
Ford did not offer F350's with 4WD until 1979.
Ford did not offer P/S in F350's until mid-year 1969 (from serial number D96,001). Ford-Saginaw P/S was used.
Oct 4, 2011 | 08:09 PM
Quote:
Originally Posted by
NumberDummy
So with said, will the ps from say a 1972 f100 or f250 work on my 68 f350. Just tryin to figure out exactly what I need to look for.
Thanks in advance
Will
Oct 4, 2011 | 09:10 PM
NumberDummy
Thanks in advance
Will
Oct 4, 2011 | 10:48 PM
I would think it would work. I did it the other way around. I used the column from a '73 F-350 and the power steering box from a '76 F-100 in my '69 F-100. No problems. Everything just bolted right in. Note: If your truck didn't have power steering to begin with you might have to change the drivers side engine mounting perch to get the P/S box in there.
Oct 5, 2011 | 06:15 AM
Don't pull the trigger so fast Bill, I believe I posted 4 wheel truck not 4wd truck. There are 2 F350s one 4 wheel, one 6 wheel, take a moment to look, vast differences between them.
John
Oct 5, 2011 | 07:22 AM
jowilker
"I see" said the blind man to his deaf friend. The problem is, I didn't
see originally, thought you were referrin' to a 4WD.
TheRedlines
Jan 17, 2017 12:09 AM
UBWoodman
Jul 13, 2016 08:44 AM
66CustomCab
15
Sep 1, 2011 09:17 AM
Matt '64
Sep 13, 2010 11:11 AM
GeneStoner
Jan 24, 2005 06:34 PM
