need gas
Old Sep 23, 2011 | 07:40 PM
the Canadian's Avatar
the Canadian
need gas
my 72 f100 with a 302 will just run dry even with a full tank does not happen all the time just once in a while no gas in carb will not start again for a while maybe 5 min it will idle but i cant drive it i got stuck on the highway 137.00 to tow it home anybody got any ideas.?
Old Sep 23, 2011 | 08:34 PM
GLR's Avatar
GLR
Fuel filter, pump, crap in tank plugging pickup tube/strainer.
Old Sep 24, 2011 | 06:20 AM
60F100's Avatar
60F100
Check the rubber hoses in the fuel line. They can deteriorate and collapse blocking the fuel flow.
Old Sep 24, 2011 | 09:16 AM
elgemcdlf's Avatar
elgemcdlf
If you find no blockage or weakness issues then I would start looking to verify 100% you have no fuel. Me: '70 F100 302 when it got warm it wouldn't restart. Acted just lke a vapor lock. It was the coil. Do you have electronic ignition? With the control module? Let it run til it quits, pack the module in ice, see if it will start.
Old Oct 2, 2011 | 11:28 AM
the Canadian
moter is a complete rebuild from bottom to top new fuel pump new fuel pump eccentric everything new. all new rubber on fuel lines only thing not new is steel fuel line from tank to pump. i took tank out and from what i could see it is clean inside and pick up tube looks good but every now and then the motor will just stop no fuel in carb completely dry. i have the vent canister disconnected vent tube just open to air i even have a vented gas cap not sure if that is good or bad. but i cant seem to find the problem.
Old Oct 2, 2011 | 11:51 AM
elgemcdlf's Avatar
elgemcdlf
Will it start if you pour fuel in the carb when it dies?
Old Oct 2, 2011 | 08:25 PM
the Canadian
yes everytime i pour gas in the carb it starts and runs till gas is burned out of carb
Old Oct 2, 2011 | 08:28 PM
elgemcdlf's Avatar
elgemcdlf
Did you use an intake gasket with a valley pan? Fuel line routing?
Old Oct 2, 2011 | 10:43 PM
williamwilliam's Avatar
williamwilliam
My truck used to do that as well. I would drive it and all the sudden it would just die and not restart. I could wait a couple of minutes and it would fire right up. Turns out it was the cartdrige filter on the fuel pump. I would check that if you have the type of fuel pump with the cartridge filter.........Alot of people dont know its a filter there and its a cheap part to replace anyway.
Old Oct 3, 2011 | 08:18 AM
elgemcdlf's Avatar
elgemcdlf
I was starting to think filter as well. Perhaps in backwards. They should have flow arrows on them.
Old Oct 5, 2011 | 08:08 AM
the Canadian
I am not using the fuel pump with the cartrige filter I am using a stock fuel pump with a inline filter i checked it all is good and clean arrow facing in right direction. I am thinking it could be the vent tube i have the canister removed and the line just open to the air. Today i am going to change the fuel line from tank to pump i am shooting in the dark.
BlackCustom77
13
Oct 28, 2012 09:40 PM
klallred
13
May 2, 2007 01:02 PM
ol gray mare
23
May 4, 2006 11:25 AM
87 4x4 flaresides
Sep 28, 2004 08:13 PM
RSCAK
1978 - 1996 Big Bronco
Jan 24, 2004 05:40 PM
