I'm preparing to replace the injectors, return lines and IP on my '89, 7.3L, IDI. Is there a tech article to follow which would guide me through these procedure? I've conducted several forum searches, but nothing is coming up for this specific maintenance/repair service; though several "loose ends" do crop up on the subject. I will also be adding an electric lift pump and removing the engine driven mechanical pump and installing a cover plate.
I appreciate any information you may be able to direct me to which may keep me from making some serious mistakes.
Dang, '94IDITurbo, you da man!!! Just what I was in search of! I'll read up and edgeumacate myself before I put my fooot in it. My sincere appreciation!
That is the guide I used when I did mine. You can't go wrong if you go by that. I had never done anything like that before and I had no problem at all!
IP replacement is easy lol....I didnt know how to do it til i tore my dad's 86 apart. Now the IP and injectors outta that is gonna go into Jayme Duty's rig here right directly.
