Rebuild no start....
Old Oct 1, 2011 | 09:27 PM
xsportplyer's Avatar
xsportplyer
Just got done doing a complete Bullet Proof Rebuid on my 2004 F-350 6.0 PSD. When I went to start the truck all it does is turn over and does not fire. I know this could be cause by a million of different things with how much work I did, but any common places to start? I am completely lost at this point.
Old Oct 1, 2011 | 09:59 PM
BobsF350's Avatar
BobsF350
pull the fuel filter on top of the engine see if its full of fuel 1st.Then it might take 3-4 tries cranking it over for 30-45 seconds.As to not burn up the starter motor
Old Oct 1, 2011 | 10:36 PM
xsportplyer
There was fuel in the filter. I eill try holdig the key on longer tomorrow. I only gave it ten to fifteen second a couple times.
Old Oct 1, 2011 | 11:00 PM
rdunagan's Avatar
rdunagan
did you do stud work or mess with any injectors or hpo? if so there is air in the system and will take a while to start
Old Oct 2, 2011 | 07:48 AM
2006powerstroke90's Avatar
2006powerstroke90
Just like Ross said...What kind of work did you do to the truck?
That would help us out a lot.
Old Oct 2, 2011 | 08:27 AM
xsportplyer
I put in a Bullet Proof Diesel oil cooler system, Replaced the head studs with ARP studs, new head stands and dummy plugs, new head gaskets, upgraded the fuel regulator spring, and replaced my entire cooling system with new radiator and hoses. I am headed over to try starting it again now. I didnt give it as long as you guys sugested, afraid i might do some damage to the engine
Old Oct 2, 2011 | 08:38 AM
Maxium4x4's Avatar
Maxium4x4
The starter will be fine, lay into and keep cranking, make sure the batteries are at full charge. If no start, you have a leak in the high pressure oil. On start up the truck will take a few days to work the air out of the system and your normal start times will be longer than usual.
Old Oct 2, 2011 | 09:14 AM
npccpartsman's Avatar
npccpartsman
I hope you filled as much of the bulletproof cooler, filter, lines, and HPOP reservoir as you could. If not you're going to be cranking a LONG time. 30 seconds if probably as long as you really want to crank before you let the starter cool for a while. Also, put a charger on the batteries and keep them hot.
Old Oct 2, 2011 | 11:31 AM
rdunagan's Avatar
rdunagan
just start and cool start and cool. but do short intervals for about 5 or so times and then let cool for awhile and then go back at it. its gonna take a long time for it to start like partsman said
Old Oct 2, 2011 | 11:58 AM
xsportplyer
Alright, Got the truck running!!!! I did fill the bullet proof system with oil as well. Now I'm just working on flushing out the rest of the oil from the cooling system from when my oil cooler failed. The only issue is I am heaing a louder than normal whining sounds when I drive it down the road. Once I get it to about 2k rpm its start and continues to whine until i let of the throttle. It sounds similar to my turbo kicking in just a higher pitch, really hoping its not something with the turbo. Any suggestions?
Old Oct 2, 2011 | 02:01 PM
rdunagan's Avatar
rdunagan
post up a video of it if you can!
Old Oct 2, 2011 | 02:32 PM
snorindad's Avatar
snorindad
I had a similar sound when I did mine and it was the y-pipe to egr cooler for me was not tight. So check all of your exhaust connections.
trevorrules
37
Sep 3, 2014 02:49 PM
wesayso
Escape & Escape Hybrid
Mar 19, 2011 11:23 PM
64F260
Mar 13, 2010 01:17 PM
custom1
Sep 4, 2006 01:59 PM
Bear Creek
Aug 3, 2006 02:04 PM
