Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Hard start
Old Mar 11, 2011 | 09:25 PM
wesayso's Avatar
wesayso
Hard start
About two weeks ago, my 07 Escape began taking several seconds for the engine to start. It turns over immediately when key is turned but does not fire until after several seconds. Runs great once it starts. Once it is warmed up, it restarts easier but still not immediately like it would a few weeks ago. Checked air filter and it looks ok. Any help would be appreciated.
Old Mar 11, 2011 | 11:02 PM
bmuhlbach's Avatar
bmuhlbach
fuel filter may be plugged I change mine like every 30,000 miles
Old Mar 12, 2011 | 07:12 AM
tomw's Avatar
tomw
Go back to basics. Fire, air, fuel. Does the ignition system need some maintenance? Does the air filter? Does the fuel pump work properly? If it runs smooth with proper power after it is started, then it seems the initial conditions for starting are not there for a few seconds. I would suspect that the fuel pressure is dropping in the system after shutdown, leaving the injectors a little starved when you first go to start the engine.
Try cycling the key from off to on to off a half dozen times before you try to start the engine. That may run the pump at each cycle to refill the fuel rail.
tom
Old Mar 16, 2011 | 05:57 PM
wesayso's Avatar
wesayso
Thanks for the info. Tried the switch on and off several times and it did not work. Then changed fuel filter and at first did not seem to make a difference but now is starting as designed. Not sure why the delay of a few days in getting back to design, but seems to be ok for now. Thanks for you all's input!
Old Mar 18, 2011 | 08:22 PM
high ho silver's Avatar
high ho silver
If it starts doing it again, take the idle air control valve (IAC) off and either clean the inside with carb cleaner or replace it.
Old Mar 19, 2011 | 11:23 PM
blupastu408w's Avatar
blupastu408w
I agree with Tom, it sounds like it was fuel pressure issue. A clogged fuel filter could definitely cause issue you describe (usually no one ever changes them ). Glad you got it corrected!
~Jason
GaryM96
1978 - 1996 Big Bronco
Apr 20, 2025 06:41 PM
PEG
1997 - 2003 F150
Nov 5, 2014 08:11 PM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
CrosbyTX
23
Sep 30, 2009 07:58 AM
Chickenmantoo
Bronco II
May 6, 2002 09:55 PM
