Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Does this mount nut/bolt look right/tight?
Old Oct 1, 2011 | 10:37 AM
TwoMuchMud's Avatar
TwoMuchMud
I recently had some clutch work done and was just going over the work they did and noticed this transaxle mount nut looks odd to me.
Notice how the nut on the right doesn't look like it's tight compared to the one on the left?
Can someone check their truck and see if it's the same way. It might be normal but is weird because the nut seems like it's not on all the way.
First picture shows where the mount is that I'm talking about. Second one is a closeup of the mount. Name:  DAkCb.jpg
Old Oct 3, 2011 | 11:41 PM
Torky2's Avatar
Torky2
I don't have the same engine/trans/or mount. So I tried looking up the mount for a 2001 with the 2.0L four manual trans on couple of parts sites, never found the mount for the manual trans.
So just looking at your pic, it looks like the stud on the right is not high enough to engage all of the threads of the nut, which ain't good. Sure would seem if the mount has two studs, that the amount of engagement would be about the same, if done properly. They just forget to tighten one of them?
Old Oct 4, 2011 | 07:24 AM
wptski's Avatar
wptski
You didn't give the model year but I see a coil pack so it has to be early. Just poking around it looks like it might be the rear transaxle support like below.
Old Oct 4, 2011 | 08:47 AM
TwoMuchMud's Avatar
TwoMuchMud
Yeah, it's a 2001 2.0L with manual transaxle and that is the rear transaxle mount.
I was thinking the same thing. It doesn't look like the threads are fully engaged. I can't remember what it looked like before so I don't know if that is normal but it doesn't look right. It's not loose though, I wonder if something is misaligned.
Old Oct 4, 2011 | 01:44 PM
wptski's Avatar
wptski
If you have three fastners holding the same piece, two are lined up, how could one be off?
Fastners come in containers holding thousands. Even when they come in small boxes, I've seen ones with no threads, deformed, etc. so I wouldn't say it was impossible to have a short one.
Old Oct 4, 2011 | 05:00 PM
TwoMuchMud's Avatar
TwoMuchMud
It might be a stud and not a bolt, in which case it is the length it is.
The nut is definitely tight though. Seems odd, until I can find someone with another Escape and see what it looks like then I just don't know.
Old Oct 4, 2011 | 11:57 PM
Torky2's Avatar
Torky2
Looking at your lower picture, I figured the two studs coming up from below were from the mount itself. Couldn't find a pic for yours, but here is an auto trans mount for the rear of the AOD RWD trans used in the 80's and early 90's, just for illustration purposes:
http://images.oreillyauto.com/parts/...e/anr/2464.jpg
Two studs come up from the isolator, those bolt to the crossmember, and the body of the mount bolts to the trans case.
In your picture, the stud on the left looks black and new. It also looks like the threads on the stud might not extend all the way to the end of the stud, that is, the stud continues on a bit at the root diameter of the threads.
Now compare that top root diameter of the left stud to what is visible of the right stud. The right stud is larger in diameter. The right stud also has some kind of mark on its end. Is it possible that some of the right stud was broken off somehow on installation, making it shorter?
I would have expected the right stud to have the same diameter at the end as the left stud, but they are different. That makes me wonder if the right is broken.
Old Oct 5, 2011 | 09:23 AM
martin_csr's Avatar
martin_csr
2002 Escape XLS 2.0L 5Mt
Photo from this morning.
Old Oct 5, 2011 | 09:59 AM
TwoMuchMud's Avatar
TwoMuchMud
Thanks Martin. Looks like the studs should be the same length.
Although now I can't imagine what the problem could possibly be. I would think if the stud is broken then the top would be jagged but it's not. Maybe it was replaced.
Old Oct 5, 2011 | 04:43 PM
martin_csr's Avatar
martin_csr
I would assume they didn't do the job right.
Dead_goldstar
2004 - 2008 F150
Jan 17, 2018 06:14 AM
Henrys son
Oct 15, 2009 01:45 PM
atrmg1610
Nov 11, 2008 08:17 PM
BombThreat
Jan 6, 2008 11:14 AM
JWB475
1983 - 2012 Ranger & B-Series
Apr 12, 2006 09:34 PM
