dies when vacuum plugged
Old Sep 30, 2011 | 09:30 PM
arron's Avatar
arron
after cleaning carb and replacing exhaust manifold (because of other issues), my 1969 f250 with carter carb will not stay running with the transmission vacuum hose hooked up to the vacuum port on the carb. if i put my finger on the port, it also dies. before having fixed the other issues, this hose was hooked up and ran fine. the guy at napa says that it should run better with my finger closing the port, not worse. can't figure it out. any thoughts? thanks.
Old Oct 1, 2011 | 01:03 AM
Cracker289's Avatar
Cracker289
Yeah I agree with him, it SHOULD be better with the port closed. Maybe increase the idle speed a little and get it to where it will idle with the vac hose in place. I'm saying this because it seems like the only reason the vac port being opened would help is if the engine was just flat not getting enough air thru to keep it running.
Old Oct 1, 2011 | 08:06 AM
williamwilliam's Avatar
williamwilliam
I did have my transmission vacuum hose hooked to the carb, but now I put it straight to the intake vacuum port. On my truck I found that when it was hooked up to the carb I would get a bad hesitation while at low speeds and then giving it the gas..........it would act like it needed to drop down to another lower gear, then all the sudden it would pick up and take off. Hooking it to the intake vacuum port solved that completely and it shifts alot better. My truck also has a mild cam and power brakes.
Old Oct 1, 2011 | 09:49 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
First thing that comes to mind is double check your vacuum hoses for correct location. Distributor should be ported vacuum, transmission to full manifold vacuum.
Old Oct 1, 2011 | 11:32 AM
78fordman's Avatar
78fordman
sounds like you need to lean up your idle adjustment fuel mixture adjustment.
hillcountryflt
May 2, 2014 09:02 AM
SeaCarr
Dec 4, 2013 11:55 PM
samtye
Feb 5, 2008 08:49 PM
bdunegan
Jul 24, 2006 11:55 AM
madmader
1978 - 1996 Big Bronco
Aug 4, 2005 09:04 AM
