Engine surge
Old Oct 31, 2013 | 03:35 PM
SeaCarr's Avatar
SeaCarr
Engine surge
Recent new Holley carb and tune up. Suddenly, usually at a stop, the vacuum will fall off. Speed up and vacuum restored. I had to speed up the idle to keep it running from 10" to 18". Squeezed off all the hoses with out any effect. Plugged the vacuum hose to brake booster, no effect.
It will run steady and suddenly drop off. If I catch it and speed up the cycle will start again. On the road at 55, all is well with good vacuum.
Where should I look next!
Old Oct 31, 2013 | 03:59 PM
montana_highboy's Avatar
montana_highboy
Was the vacuum advance switched from manifold (full) to ported (timed) during the carb swap/tune-up?
Old Oct 31, 2013 | 05:09 PM
devino246's Avatar
devino246
Did you actually tune this new carb or did you just slap it on there?
Old Oct 31, 2013 | 06:32 PM
SeaCarr's Avatar
SeaCarr
Vacuum advance
The vacuum advance is connected from the upper right hand vacuum port on the carb.
Old Oct 31, 2013 | 06:34 PM
SeaCarr's Avatar
SeaCarr
Carb tune
A local auto repair adjusted the carb after it was installed. It ran very well for several months although not often. Most of the time it sits in my garage.
Old Oct 31, 2013 | 08:19 PM
devino246's Avatar
devino246
From your description, it kind of sounds like it's flooding. The next time it happens, pop the hood, pull off the air cleaner, and look down the throat of the carb with the engine still running. If it's flooding, you'll see fuel dripping down into the throat of the carb.
Old Oct 31, 2013 | 10:12 PM
march's Avatar
march
Just curious how you know your losing vacuum. Do you have a vacuum gage in the cab? Where is it connected?
Based on your description, it sounds like you are connected to ported vacuum and therefore have no vac advance at idle. Otherwise a leaky vacuum advance canister could be you problem.
Old Oct 31, 2013 | 11:21 PM
SeaCarr's Avatar
SeaCarr
Vacuum
Yes, I have a gage in the cab. I checked that line and it is ok. It comes from the manifold. When the event takes place the vacuum dives below 5. If I let it continue I'm sure the engine would die.
I guess it is off to the local mechanic.
Old Oct 31, 2013 | 11:26 PM
SeaCarr's Avatar
SeaCarr
engine surge
Kind of difficult to do that in traffic. I live about 20 miles from town. This morning it started fine and ran on the highway ok until I started braking in town. I thought it was the power brake booster but I plugged that line and it still wouldn't idle. Squeezed off the other vacuum lines and no change. Tightened carb flange bolts. Squirted wd40 around the base and vacuum connections. No change. Moved the timing around, no change.
Guess it is off to the local mechanic.
Old Oct 31, 2013 | 11:35 PM
montana_highboy
Was the vacuum GAUGE switched from manifold (full) to ported (timed) during the carb swap/tune-up?
I had a brain fart on my earlier post......I meant GAUGE, not ADVANCE.
Old Nov 1, 2013 | 12:04 AM
SeaCarr's Avatar
SeaCarr
Vac advance
I had several carbs over the years when the engine had a 2bbl. I can't remember where the vacuum advance source was. The present engine is a 390 thunderbird w/ Holley 4bbl. The Holley people specified using the port on the carb and there is little to no vacuum at that port at idle.
Old Nov 1, 2013 | 12:05 AM
SeaCarr's Avatar
SeaCarr
Vacuum
Vacuum gage is from the manifold.
Advance is from the carb port.
Old Nov 1, 2013 | 11:02 AM
montana_highboy
That's correct, you want ported vacuum for vacuum advance (most carbs have ports for both ported and manifold vacuum) so just be sure you're on a port above the throttle blades.
That's correct as well, your symptoms led me to believe maybe the gauge was sourcing its vacuum signal from a timed port.
At this point i'd start spraying around for vacuum leaks, check everywhere, hoses, intake, carb, booster, etc.
(EDIT: I just noticed you had a FE so it's possible to have a vacuum leak under the valve covers that cannot be found using the spray technique)
Old Nov 1, 2013 | 12:12 PM
SeaCarr's Avatar
SeaCarr
Engine surge
After sleeping on this, maybe I'm looking at vacuum being the problem but it is only a result of the engine speeding up and slowing down. When the engine starts cold, the choke is on and the idle is fast, vacuum high. After warm up is when the problem starts. Driving at 55 all is normal. At idle, the engine surges and almost dies then speeds up again. A rhythmic pattern. Sort of like getting gas then not.
Old Dec 4, 2013 | 11:55 PM
SeaCarr's Avatar
SeaCarr
You were 100 % correct. After back and forth with Holley and a $75 spacer they sold me to fix the problem which it did not, Holley took the carburetor back and found the floats were bad. They repaired the carburetor at no charge except for my $20 to send it to them and my out of pocket at the local garage.
Runs fine now. I could have bought another new carburetor!
arron
Oct 1, 2011 11:32 AM
GELGIN58
Jul 26, 2008 05:01 AM
bdunegan
Jul 24, 2006 11:55 AM
ohiofossil
Jul 4, 2006 08:58 AM
madmader
1978 - 1996 Big Bronco
Aug 4, 2005 09:04 AM
