swapping in an IDI?
Old Sep 30, 2011 | 10:48 AM
lance65's Avatar
lance65
swapping in an IDI?
I have searched,so before anyone tells me about the search button, I have used it.
My question is how many have swapped in an IDI (6.9 or 7.3) into a 2wd dentside? I am not looking for info on a cummins swap as I dont have one, I do however have an IDI non-powerchoke. Not trying to be rude,just not interested in hearing "you should swap in a cummins".
Thank You for any info
BTW it will not be turbo'ed
Old Sep 30, 2011 | 10:57 AM
jas88's Avatar
jas88
As long as you can fab the motor mount perches, you should be good to go as long as you are not using an E4OD trans. C6 or ZF5 will not need any wiring, and the engine only needs 12V to the injector pump in order to run.
Old Sep 30, 2011 | 11:10 AM
jas88's Avatar
jas88
This may give you some leads:
6.9 in 78(9) Bronco swap - Diesel Forum - TheDieselStop.com
Old Sep 30, 2011 | 02:44 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
I was thinking about the same thing for quite a while: https://www.ford-trucks.com/forums/1...questions.html One member here has two trucks (both 2wd) with IDIs that he swapped in himself. His user name is 1967 Turbo 6.9
Sam
Old Sep 30, 2011 | 04:23 PM
lance65's Avatar
lance65
Thanks guys. I am also gonna be checkin out the van front spindles and doing some measurements(king pins,tie rods,etc...) to see if I can switch to front swteering to make fitting it easier.
Old Oct 1, 2011 | 12:33 AM
OrFordGuy's Avatar
OrFordGuy
67turbo6.9 is the guy to talk to he helped so much with the 6.9 turbo conversion on my 79 supercab 4X4 both of his trucks are 4X2s... as for the van slpindles how are you goona connect a rear mounted box to front mount steering????
Old Oct 1, 2011 | 09:49 AM
lance65's Avatar
lance65
I would be changing to a front steer box and linkage from a later model F series.
tyler.dunn94
Apr 13, 2017 11:19 PM
tyler.dunn94
Apr 13, 2017 06:26 PM
Yukon_IDI
Sep 28, 2015 04:45 AM
bertil
Aug 22, 2014 01:16 PM
mudguts
Oct 5, 2011 10:11 AM
