engine swap
Old Aug 21, 2014 | 07:14 PM
bertil's Avatar
bertil
engine swap
I recently came into the possession of a 1994 7.3 turbo in fair shape and am wondering what I need to do to install this engine in a 1977 Ford F350 2wd w/an auto trans
Old Aug 21, 2014 | 07:20 PM
BruteFord's Avatar
BruteFord
Welcome to FTE
Step one, is it IDI or PS, could be either in 94? Next step, what transmission is behind the 7.3? Step three, search, this has been done a few times, and I know there are a few build threads on it, if I come across one I'll post it up for ya.
Old Aug 22, 2014 | 08:50 AM
bertil's Avatar
bertil
engine swap
This regards an engine swap of a 400 ci to a 7.3 turbo in a 1977 Ford F350 2wd.
The engine I have is a 1994 7.3 turbo power stroke?. I plan to use either a C-6 or E4OD as I have both.
One of my problems seems to be the amount of electronic controls on the engine that are, it appears only to be found on a donor vehicle ie. trans, shift and injection system. The engine has no wiring harnesses on it.
I also have an older 1985 6.9 IDI that can be swapped as the only wiring needed for the diesel is connected to the injection pump.
Old Aug 22, 2014 | 01:16 PM
UNTAMND's Avatar
UNTAMND
I think the only transmission in the 94 psd was a manual.
The psd requires a lot of wiring to be swapped. There's two computers basically, special throttle pedal, and few other things.
You say you have a 7.3 powerstroke... With a question mark.
Is it an idi like your 6.9, or is it an electronic diesel with direct injection.
Which is it.
The c6 from the 6.9 may work, but the c6 from the 400 won't bolt up. The e4od is all electronic and will require a harness and computer from a newer automatic truck.
tyler.dunn94
Apr 13, 2017 11:19 PM
lance65
Oct 1, 2011 09:49 AM
chevma-67
Sep 28, 2008 05:28 PM
77highboyowner
Oct 30, 2007 12:43 PM
ace866286
Jan 25, 2005 01:17 PM
