GPR and PCM
Old Jan 21, 2010 | 06:59 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
GPR and PCM
alright i have absolutely no problems starting my girl in the cold. however my buddy ha an 02 F350 powerstroke bone stock and is having some problems. he was telling me about all kinds of problems he had with the gpr before the warranty went out with ford on his truck and he is back to having them again. apparently hos gpr went bad so i kept telling him about the stancor unit but he ended up buying a different one. this gpr if it even is one is supposedly bad as well out of the package. not unheard of but i am wondering if he even got the right thing. i told him to order the stancor unit and he should be fine. he doesnt want to spend the money on another gpr until he is convinced his pcm is working right and sending the right signals to the gpr for proper operation. i did have him jump the terminals on the new gpr and it started up like normal. thats why i think the gpr he got was a doa. what can i have him check or do to show that the pcm is working correctly with the gpr. or does the pcm even have that much to do with the gpr? i keep trying to get him to change to synthetic oil also but im not having much luck convincing him about all the cool stuff he can do to the rig to make it better. any ideas?
Old Jan 21, 2010 | 07:53 PM
Ziggy.'s Avatar
Ziggy.
You can check the signal wire on the GPR that comes from the pcm with a multimeter or a test light to see if it is even getting the signal for the relay to turn on, if it is not, check all the wiring for cuts, burns, loose connections etc all the way back, if it is not getting a signal and the wires look good, see if you can find someone nearby with AE to take a look at the pcm signals and inputs for the GP's and relay, as well as the oil temp sensor input and voltage.
Old Jan 21, 2010 | 08:17 PM
PaysonPSD's Avatar
PaysonPSD
The quick and dirty way to test the GPR for operation is to either listen or feel for it to operate. If it is operating then check that it is passing the battery from terminal 2 (always hot) to terminal 4.
If it is not operating perform the following:
To test the GPR lift the wires on terminals 3 & 5 (the small wires). Apply battery to terminal 3 and then ground terminal 5. You should hear and/or feel the GPR operate. While operated you should be able to measure battery at terminal 4. Terminal 2 should always be hot.
Test PCM control with terminal 3 and 5 lifted. Turn key to on position. The wire lifted from terminal 3 should have battery and the wire lifted from terminal 5 should have a ground. Test while vehicle is cold and remember, depending on the temp, the control leads will only be active for a max of about 120 seconds.
Old Jan 21, 2010 | 08:59 PM
StrokedRanchero's Avatar
StrokedRanchero
Did he get an actual GPR or a regular starter relay? There is a difference I believe. Ford part # is F81z-12b533-ac
Old Jan 21, 2010 | 10:04 PM
indyF-350psd
i dont know which gpr he got but its not a ford one. thanks for the input ill let him know.......
Old Jan 22, 2010 | 08:37 AM
shovelrog's Avatar
shovelrog
This is a sore subject for me, because I purchased a replacement GPR from Orieleys and appaently it was a starter relay in a GPR box. One of the small terminals was a different size and copper color. But like an idiot I installed it anyway even having to finf a nut to fit the copper small terminal. Started it up and it wouldn't shut back off!. I thought maybe I had the small terminals reversed (I'm an electrician by trade so this brain fart hurts even worse). So I swapped the small wires and it would shut off but apparently I fried the contacts in my PCM that send the ground. I've ohmed out the wire to the firewall plug. So now I have a push button for my GPR. It gets worse. I purchased a remanufactured PCM from the big name place out of Florida for around $300. installed it without my DP tuner in and it ran like ****, the OD light was flashing and it had no power. So instead of returning it with the seal intact like an idiot again I got the bright idea. Maybe it would work better with the DP chip installed. Well it didn't and breaking the seal to install the chip means no replacement from the place that sold it to me. So I had to send it back as my core and it was a $300 experiment. My *** is still sore from all this reaming! Of course my stupidity was mostly the problem. Can I get a hug? ha ha
Old Jan 22, 2010 | 03:33 PM
indyF-350psd
how much battery should be at terminal 3? 12 volts or like a half a volt?
Old Jan 22, 2010 | 04:20 PM
PaysonPSD's Avatar
PaysonPSD
I answered your PM.
I can't remember exactly what I measured but I'm quite sure it was 11+ volts.
Old Jan 22, 2010 | 06:10 PM
Smokin''s Avatar
Smokin'
Smokin
The plastic relays are also pretty fragile. If he torqued that sucker down with a socket he could've damaged it somehow.
If he jumped the posts and it fired normal its the GPR.
Old Jan 22, 2010 | 07:16 PM
tdpower's Avatar
tdpower
re
That is true unless the pcm is not sending the ground signal to the gpr . Looks like #3 in Robin's post. Lisa, what are you doing at home on a happening Friday night?
Old Jan 22, 2010 | 07:21 PM
Izzy351's Avatar
Izzy351
You could also move the wires to the AIH relay instead. It's a good relay too. And the only reason why mine is still there. Built-in backup GPR!!
Old Jan 22, 2010 | 07:31 PM
Smokin''s Avatar
Smokin'
Smokin
Happening Friday night? I live in Cedar Rapids Iowa and all of my friends and family are 600 miles away...if that answers your question.
Trevor Kohler
Apr 18, 2016 05:04 PM
greagin
Jan 18, 2016 02:01 PM
powerstoked!
Dec 15, 2015 09:47 AM
Brother Les
29
Dec 29, 2011 07:13 PM
whitesdford
15
Feb 19, 2010 10:19 AM
