C6 trans question
Old Sep 29, 2011 | 06:52 PM
SeaBeeCm1's Avatar
SeaBeeCm1
C6 trans question
Ok we have decided to buy a C6 trans for our 390 motor. What kind of donor vehicle do I need to look for in the junk yard ?
Old Sep 29, 2011 | 09:41 PM
elgemcdlf's Avatar
elgemcdlf
Assuming you are going to have it gone through (which I would definitely do on a 40 year old used trans) I would just hit a local tranny shop and tell them what you want. If they don't have one on the shelf they should be able to build you one pretty quick. Anyway the answer to your question would be just about any full size Ford product from the '60's.
Old Sep 30, 2011 | 07:49 AM
SeaBeeCm1's Avatar
SeaBeeCm1
do I need to stay with a particular engine size?
Old Sep 30, 2011 | 08:05 AM
elgemcdlf's Avatar
elgemcdlf
360/390. They have a round shaped bellhousing instead of a flat top.
Old Sep 30, 2011 | 05:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6: The converter (bell) housing is part of the transmission case.
Old Sep 30, 2011 | 06:35 PM
jowilker's Avatar
jowilker
You want to get one from a truck not a car because the shift arm on the side of the tranny is positioned differently.
Easy pickins 73-76 F100/250/350 connected to FE 360/390.
John
Old Sep 30, 2011 | 07:48 PM
elgemcdlf's Avatar
elgemcdlf
Yes I felt weird typing that. Figured it was the easiest way to get the point across.
Old Sep 30, 2011 | 07:58 PM
SeaBeeCm1's Avatar
SeaBeeCm1
Thanks to all I am going to try and sell my 352 with cruisematic trans to fund for a c-6 and other parts I need to continue the project
Old Sep 30, 2011 | 08:07 PM
elgemcdlf's Avatar
elgemcdlf
Ok you have exactly what you need. Look at your Cruiseomatic where it attaches to the engine. What would be the bellhousing area on a manual. You need a C6 that looks just like that.
Old Oct 1, 2011 | 05:48 AM
jowilker's Avatar
jowilker
You might want to find and buy a donor 73-76 pickup with 360/C6 combo that is not in a junk yard. Should you want to do the power steering power disc brake upgrade it will have all the parts needed.
The column shift is different between the C6 & C-O-M, & needs to be swapped also.
Purchasing a donor also gives you a basis to buy replacement parts from. Should I sell the truck I can tell the buyer everything below the chassis need to be ordered for a 76 F100. When you go to the pick & pull getting a part here & there you will be back here asking for help after you forget where it came from.
John
ryanf77
16
May 7, 2015 09:51 AM
gary85314
Nov 24, 2008 02:16 PM
tankrsc
Oct 16, 2007 08:45 PM
shrike
May 12, 2004 12:46 PM
