Battery Draw Issue
Old Sep 29, 2011 | 01:55 PM
Bpayton's Avatar
Bpayton
Battery Draw Issue
I posted a little while ago about a battery draw issue I was having just wanted to post what I found. I want to I start out saying the front window leaks and I haven’t taken it in yet to be fixed and I have read that this can cause some problems under the dash. I brought the truck into work today and we started looking for the draw. I was drawing .34 milliamps and started pulling fuses and then I got to fuse #15 and the draw went to almost nothing. #15 5A Stop Lamp Switch (Logic), PATS, GEM I thought I read somewhere that the GEM box can go bad on these. Does anyone know how much this will run or if they have a similar problem?
Old Sep 29, 2011 | 02:34 PM
jasonodsky's Avatar
jasonodsky
I believe the GEM goes bad from getting wet when the windshield leaks. If I remember correctly what I've read here.
Old Sep 29, 2011 | 06:29 PM
LOP223's Avatar
LOP223
.34 milliamps is nothing. Are you sure that's what it read? 60 milliamps is the benchmark we use for excessive draw.
Old Sep 29, 2011 | 06:33 PM
Bpayton's Avatar
Bpayton
It was bouncing between 342 and 357 milliamps
Old Sep 30, 2011 | 01:22 PM
Gene Horr's Avatar
Gene Horr
.34 amps. That is a material amount. With new batteries a day or two shouldn't matter but longer than that and it becomes noticeable when you try and start it.
Old Sep 30, 2011 | 03:40 PM
dabaws's Avatar
dabaws
last time i checked gems were around 150 used :/, ye i read it's a common problem from leaking windshields
RaptOut
1997 - 2003 F150
Jul 17, 2012 08:06 AM
mberry62
1997 - 2003 F150
Oct 4, 2008 10:27 PM
bigbird_6371
1997 - 2003 F150
Sep 1, 2008 08:47 AM
shane7209
1997 - 2003 F150
Jul 7, 2004 08:08 PM
007
1997 - 2003 F150
36
Oct 11, 2001 07:49 PM
