Sponsored by: Auxito
HELP!!!!lost on a few things
Old Aug 31, 2008 | 02:28 PM
bigbird_6371's Avatar
bigbird_6371
I have a 2002 F150 Supercrew and a few things has been happening I just can not figure out...first I have heard a clicking noise from under the stering wheel I have read a few people say check the fuse box and make sure it is not wet.. it is not but today when I started the truck it happened again while the truck is running it was trying to turn over again...I turned it off and you can hear it trying to start by it self...I know it sounds funny...can any one give my a clue were to go from here...also the other day it was running like it had a mis the scanner I have misfire in cyc. 8 I removed the coil to #5 and it was running fine till today when this all happened...Oh I Woke up this morning to dead battery this is how my day started...thanks if you can help
Old Aug 31, 2008 | 07:57 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
I'll bet we can get you some help. How old is your battery?
Old Aug 31, 2008 | 10:47 PM
LxMan1's Avatar
LxMan1
Welcome to the forum. It is possible that there is a small leak at the windshield that has allowed water to get into the GEM module. This is located behind the fuse box. When this happens, all kinds of weird stuff can happen. This module controls everything from delay wipers to the PATS key system to the auto down drivers power window.
Also a weak battery like mentioned above can cause problems. Have you ever noticed if all of your gauges do a full sweep to the right when you first start it?
Old Sep 1, 2008 | 08:47 AM
bigbird_6371
thanks...the battery is about 2 years old....yes the dauge go to he right and back...but last night I was driving and the seat belt signal was going off and the radio was turning on and off..I replaced the battery terminals to see if that will help
