Hand Grip ?
Old Sep 28, 2011 | 10:14 PM
aofords's Avatar
aofords
Hand Grip ?
Has anyone ever installed a hand grip on the passeger side A pillar ? I have a 97 4WD F250. A couple of my friends have a difficult time getting in my truck. My truck is stock height, no big wheels, tires, or a lift kit. So if anyone has installed a hand grip, like the ones on late model trucks, I would appreciate anyone helping me out....thanks
Old Sep 28, 2011 | 10:54 PM
SideWinder4.9l's Avatar
SideWinder4.9l
I haven't actually did it...But have looked into it...
1) The A-Pillar is actually made weird, and has a weird angle, so a piece of metal will need ti be welded in, to make the angle correct for mounting the handle on...
2) The A-Pillar trim, will need 2 holds cut, to allow the ends of the handle to pass through to the metal area previously welded in for structure, etc...
3) After aligning, cutting the holes (A hole saw attachment would be perfect at this point) and mounting the handle, etc....I'd recommend a couple rubber grommets to fill in the gaps and prevent the handle from putting pressure on the trim panel....
Otherwise....Have at it....
Old Sep 28, 2011 | 11:14 PM
Encho's Avatar
Encho
The Southernmost Mod
I don't, but i have seen them installed. If it where me in your place, i would search for a side step, it will be easier to install and they are a great help getting in. The grip would probably require some internal gusseting to ensure the body panel doesn't bend because on the passenger's weight.
Old Sep 28, 2011 | 11:30 PM
SideWinder4.9l
2) The A-Pillar trim, will need 2 holds cut, to allow the ends of the handle to pass through to the metal area previously welded in for structure....
<fiiiiiiiilllllllllll>
Old Sep 28, 2011 | 11:41 PM
CJM8515's Avatar
CJM8515
Id just install a grip handle on the outside behind the door area.
Old Sep 29, 2011 | 07:45 AM
Encho's Avatar
Encho
Hmmm i thought that was what he meant (behind the passeger's door, missed the A-pillar), but anyway, the A-pillar isn't the best spot neither...
Old Sep 29, 2011 | 11:52 AM
86F150302's Avatar
86F150302
Best bet is to tell them to quit being a puss
4x484150
15
Dec 25, 2013 10:15 PM
dyingtolive
Jan 26, 2011 09:14 PM
JP_McCann
1997 - 2003 F150
Jul 30, 2008 12:53 AM
jpb222
Paint & Bodywork
32
Sep 29, 2004 10:10 AM
Big
Apr 4, 2002 06:39 PM
