Dark green are 100, and light green are 200 each. Rep from those with more rep is worth more rep.
I also believe that the reps are worth more points when you write a thank-you note in the comments box.
It is always helpful to add a note when you "hit someone w/ rep points". Tell them why you did so, or just say "thank you for the helpful post". You do a good job of this William when you rep folks!
I just received another rep, with a note, and went from 37 to 38 so that may not be true.
EDIT: Just got a rep from Kep4, it bumped me up 8 points
What does a negative rep do? I told a story about my friend getting his tags taken for having illegal tint and an exhaust cut off before the cat and some guy gave me a negative rep cause he thought I made it up.
I also have two reps with a grey square next to them, guess that means neutral
Always leave a note when you Rep so the person knows why you gave it out. I tossed some around to some of ya. Enjoy!
Mark, AKA Bismic, always deserves Rep for all he has done for the 6.0 Forum and owners.
I wanted to add that I've only given negative Rep one time and I regretted it the next day. I suggest that users think carefully before giving anyone negative Rep.
