460 EFI Miss
Old Jul 30, 2010 | 09:13 AM
Crabby144's Avatar
Crabby144
460 EFI Miss
I am on just about to go nuts!!! My truck runs great as long as i keep the rpm's above 2000 or below 1500. So I have a miss between 1500 and 2000 rpm's. I have changed everything ignition wise, fuel pressure is 34lbs, timing at 10 maybe a little more advanced but not much. no codes. just can't find anyone who has had this problem or anyone who know what it might be. any help?
Old Aug 10, 2010 | 08:42 AM
Crabby144's Avatar
Crabby144
anybody???
Old Aug 10, 2010 | 10:21 AM
timalew's Avatar
timalew
If you find out, please lemme no. Mines doin the same thing!!! Wish I could help ya. If I do figure it out I'll let you know
Old Aug 10, 2010 | 10:23 AM
leavy20's Avatar
leavy20
sorry i dont know either. but have you tried checking trouble codes?
ps. as an owner of a 460 with questions i have noticed that there seems to be less knowledge or at the very least less answers for us.
Old Aug 10, 2010 | 10:32 AM
timalew's Avatar
timalew
yep...ha ha
Old Aug 10, 2010 | 10:50 AM
leavy20's Avatar
leavy20
i did just have a thought for you guys though. have you tested your TPS sensor, that may be what it is.
Old Aug 10, 2010 | 10:59 AM
Crabby144's Avatar
Crabby144
i have thought about it being the TPS, but i had one laying around and put it on and didn't make a difference. just hate to spend 30 bucks for a new one and it not change anything. might go ahead and do it when i get time. but i have done everything. just weird cause it was running fine and one night just starting acting up, timing backed off and started running like it was to far advanced. changed the dizzy and retimed and runs fine except the miss. I am used to hearing nobody knows whats wrong. i have asked everyone. codes to come through for TPS but I sometimes have had a scanner tell me nothing was wrong and there was.
Old Aug 10, 2010 | 11:00 AM
Beastlyforddude's Avatar
Beastlyforddude
does it only miss once the engine is warmed up? 460's run pretty hot and throw off a lot of heat. i had to put spark plug wire heat insulators on are 460 so it wouldnt interfere with the spark.
Old Aug 10, 2010 | 11:03 AM
Crabby144's Avatar
Crabby144
nope, mine does it as soon as i get in it and take it down the road cold.
Old Aug 10, 2010 | 11:05 AM
leavy20's Avatar
leavy20
here is a link on how to test (video) your tps, all you need is a voltometer with a 20K OHM setting.
How to test and replace your car's throttle position sensor | Video « Wonder How To
Old Sep 24, 2010 | 07:47 PM
grayfoxbody's Avatar
grayfoxbody
stock fuel press
i was trying to find the stock f.press when i saw this the manual 35 to 45 fp w/vac line plugged from the the reg .how old is your o2 sensor? some times they don't throw a code till totaly wasted? also after 100,000 the fuel ca get weak as these were the same as the mustang 88ltrs
Old Sep 25, 2010 | 03:07 AM
timalew's Avatar
timalew
Mine was due to using Bosch platinum plugs...went back to stock autolites and all is well.
Old Sep 27, 2010 | 06:46 AM
Crabby144's Avatar
Crabby144
Thanks for letting me know. I wish that would fix mine, i changed mine and it did help a little bit. it still jerks at around 1800 or so, but once it's pass 2000 rpm's and runs just fine. don't know. i think all my electrical is coming off and i am buying the adapter plate for the the carb.
Old Oct 11, 2010 | 10:59 AM
Crabby144's Avatar
Crabby144
well the truck as been sitting again, i changed out the map sensor and put in another dizzy. still nothing, i did play with the timing a little, and the jerking kinda went away a little. it kinda drivable now. but still not fully fixed. i had to guys tell me could be the cam. said the a lobe on the cam could be gone. still find that hard to believe, but it does sound like something timing related since i got it to run better, i would think it would do it all the time. it still cranks over hard after it's warm.
Old Oct 11, 2010 | 03:23 PM
collinsjon's Avatar
collinsjon
just a thought, but maybe a cam lobe is bad. Idk just tryin to toss up an idea
