It is most likely a broken wire in the harness where it goes from the body to the door. Many people have had this problen with door locks, windows or mirrors.
So do you know how the mirror is removed to check the harness?
Correct me if I'm wrong but if the switch still moves the mirror to the left, up or down, I don't think the wire connection is bad. I also don't think the switch is bad but the motor assembly or wire connection, or maybe just a need of some lube here.
You can just remove the mirror itself (it snaps out) to access behind it without removing the whole assembly. However, to remove the whole assembly, you must remove the small triangular piece of the door assembly where the mirror mounted, partially remove/lower the door panel, remove 3 nuts that hold the mirror assembly onto the door, and disconnect the wiring harness to completely remove.
My opinion, snap the mirror off first and check behind it. You might save lot's of time and aggravation.
If you need new ones, look at this deal!
I was looking for something else and saw this special.
is a hell of a deal. I went to salvage and paid 25 bucks for a heated but w/o signal. Nice to know I need the one that is 130 bucks. But, is having a signal really worth the 100 bucks extra?..I think i can live w/ just having driver side signal for now lol
