Electric fuel pump conversion
Old 09-28-2011, 12:16 PM
Splatts's Avatar
Splatts
Splatts is offline
Anyone installed the electric fuel pump conversion kit from dieselsite.com?? Looking for the install guide and parts list for it.
Old 09-28-2011, 12:22 PM
Splatts's Avatar
Splatts
Splatts is offline
Just the install guide would be great
Old 09-28-2011, 12:48 PM
Splatts's Avatar
Splatts
Splatts is offline
I believe its the CPR fuel system
Old 09-28-2011, 12:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Doesnt the system comes with instructions?
http://www.dieselsite.com/pdffiles/DPJan2010OBSCPR.pdf
Old 09-28-2011, 01:11 PM
Splatts's Avatar
Splatts
Splatts is offline
Ya but I am being a cheap ***. $1200 for the kit is steep. Just lost my fuel pump
The other day and looking to save some $$ with the conversion to an electric fuel pump.
Old 09-28-2011, 02:02 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
BIGRED 7.3L is offline
To save money you should replace your fuel pump with a stock fuel pump. You can build your own electric fuel system for about half of the kit you mentioned. Others have done it here on FTE.
Old 09-28-2011, 02:10 PM
Splatts's Avatar
Splatts
Splatts is offline
That's what I want to do is built my own. But I ain't no master mechanic or nothing. So I was goin to get all te parts myself and use the install guide as a reference to install it
Old 09-28-2011, 08:00 PM
fordpride's Avatar
fordpride
fordpride is offline
Old 09-28-2011, 09:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Old 10-02-2011, 07:09 AM
Splatts's Avatar
Splatts
Splatts is offline
Got the fuel bowl out the Fpr out and the turbo is putting up a pretty good fight! When I get that turbo out what are some things I should do. I noticed a bit of oil behind the turbo on what I believe it the ebfv. Probably the O rings in the actuator. I saw another guy had the same issue. Any other words of advice?
Old 10-02-2011, 07:26 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
I'd eliminate the ebpv if I were you. Make sure you get new orings for the turbo and pedestal for when you reinstall it. Here are some ways to work with the ebpv. I did what gobstopper did. Clay also sells a pedestal with the ebpv deleted on it. My tymar dp came with instructions how to remove the flapper out of the turbo exhaust. Basically just drill out a couple rivets and a freeze plug is needed iirc.
https://www.ford-trucks.com/forums/9...pv+rod+removal
Old 10-02-2011, 08:20 AM
Splatts's Avatar
Splatts
Splatts is offline
If u don't need it then why is it there? What r the benefits
Of removing it?? My old Fpr was nasty!!!
Old 10-02-2011, 08:30 AM
427 fordman
It is just for faster warmup in cold weather. It does nothing else unless you'd wire it up for an exhaust brake. It does restrict air, maybe not a lot when its open, but it does. Removing it will allow for better exhaust flow.
Old 10-02-2011, 09:51 AM
Splatts's Avatar
Splatts
Splatts is offline
So I can totally remove it from the turbo pedestal and gut the flapper dealeo. The fuel pump sits right in the front of the turbo almost under the pedestal? What's the big silver thing infront of that, hpop?
Old 10-02-2011, 10:24 AM
427 fordman
Yes you can totally remove it from both places, that is what I did. You are right on the fuel pump and the hpop. The resevoir for the hpop is on top of it.
Quick Reply: Electric fuel pump conversion
