Trouble with 7.3L again.
Old Sep 28, 2011 | 01:47 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Got tired of mileage it get now. Before that it was 17 mpg now it 13 or less. Fuel gauge moving to E quicker than I usually see.
I order new EBP sensor let hope that fix PO475 and transmission shift issues. Old one was randomly work right when it stop work then trans shift so hard.
I been try find way to hook fuel pressure gauge. Problem is I had gas pressure gauge for one with schraeder valve.
There are lag on acceleration pedal I would say random 3/4" nothing happened that on highway. If it toward to big hill you would push 1" more it didn't exact respond for like couple seconds before boost up.
I forgot code but it say Exhaust low is that related to Turbo EBPV?
Old Sep 28, 2011 | 06:09 AM
bfife's Avatar
bfife
still plays with trucks
you can pick up a kit from Guzzle that installs a schraeder valve adapter in the fuel filter bowl.
Old Sep 28, 2011 | 08:19 AM
Milwaukee1979F150
Thank you so much I was look for one like that and know it must be there one. Search for 2 months they keep direct me to that adapter sleeve which I don't want.
Old Sep 28, 2011 | 11:43 AM
kawcrasher's Avatar
kawcrasher
You need the adapter to put the schrader valve on. Fuel pressure test ports are #4 ORB, all the schrader valves I found are NPT. You need part #13-001 and 13-005.
Old Sep 29, 2011 | 12:03 AM
Milwaukee1979F150
Not understand clearly. You say this one won't work until I buy adapter? Replacement O-rings for Ford Diesel Engines
Look like I need order Adapter
Old Sep 29, 2011 | 12:09 AM
BigAlsPSD's Avatar
BigAlsPSD
Yes you need the part that you posted Schrader Valve as well as the adpater #4 ORB to 1/8" FNPT Adapter
Old Sep 29, 2011 | 12:12 AM
twags6's Avatar
twags6
The adapter goes from tapered pipe threads (on the schrader valve) to straight pipe threads with an o ring (on the fuel bowl).
Plowboy34
1983 - 2012 Ranger & B-Series
Aug 1, 2017 10:10 AM
throwdown
15
Dec 19, 2011 01:51 PM
Fordbronco69
34
Feb 24, 2010 08:19 AM
cef2lion
Nov 17, 2006 12:40 PM
Jaaaaaaackman
May 29, 2006 11:22 PM
