Fuel pressure gauge question
It could be either the fuel pressure sender or a sticking FPR poppet valve.
If it is the poppet valve you need to rebiuld the FPR. Kit availble at Dieselorings FPR Rebuild Kit.
If you have to rebuild FPR I suggest you install the Dieseloring Billet FPR Housing.
I think it might be good to rebuild the FPR with the kit that Robin posted. I experienced similar symptoms and it turned out to be the FPR.
Well, I rebuilt the FPR and hopefully this will stop the pressure spikes. However, I am still getting 75# of pressure. I have the first generation RiffRaff FRx which is shimmed to mod the pressure.
After the rebuild I was getting 75-80 PSI at idle. I talked to Clay and he suggested putting the old spring back in instead of the new one that came with the kit. I did this and I am still getting 75 PSI. The old spring is visibly smaller and shorter than the new stock replacement. The pressure fluctuates at idle as well. Just a few pounds, but it still moves up and down.
Any thoughts or suggestions??????
Patrick, was getting the same reading with my first gen FRx, but it didnt come with a different spring. I usedthe stock one, and all day long, saw 75psi, then spiked to 80-ish. Wasnt happy with that, so took FPR apart, wet-sanded the poppet, re-installed with cutting 1 turn of the spring off, now it sits at 62psi...woohoo.
