Axle code mystery!
Old Sep 27, 2011 | 11:41 PM
Junior Junior's Avatar
Junior Junior
Axle code mystery!
Here is a photo my door sticker. Pretty standard stuff. The truck is a 1982 F100, 2-wheel drive, 300 straight six, 3-speed manual, shifter on the tree. Made in canada. That would explain the 195/75 hockey puck tires.
The thing I'm perplexed about is this "075" axle code. I've looked EVERYWHERE to find out what that means. Several repair books, this here site, extensive use of google-fu, and nothing comes up. Apparently, this either didn't exist or was some kind of special order.
All I know is, the gear is TALL. Several long highway trips of over 100 miles have netted me mpg's in the 25-27 range. This is absolutely no exaggeration. Does anyone have any idea what "075" is? Not knowing is driving me nuts, and not up very many steep hills.
Old Sep 28, 2011 | 07:35 AM
Sw1tchfoot's Avatar
Sw1tchfoot
I couldn't find it either, but it is probably 2.46.
If anyone can find it NumberDummy can.
Old Sep 28, 2011 | 08:33 AM
1983F1503004x4's Avatar
1983F1503004x4
That's some pretty wicked gas mileage for the old 300 6!
You could crawl up under the truck and look for a buck tag on the axle, those usually have the gear ratio's listed on them. You might have to pull out the bolt that holds it on to read the gear ratio. Mine was about the size of a credit card and metal, on my '83 F150.
Mine is something like:
_________________________
WDRC (There are numbers here, can't remember em')
3 08 8 8 (more numbers go here)
My 3.08 was covered up by the bolt head. 3 08 is the gear ratio, and if it was 3L08 it'd be limited slip. 8 8 is an 8.8 rear end. You're truck is probably a 9'' rear end and is pretty easy to spot. If it's a 9'', you'll have just a smooth differential looking at it from the back with a big hump, and no bolts on the side opposite of the drive shaft. If it's an 8.8 rear end, you'll have a differential cover on the back and the tag will say 8.8. 9'' rears were used up until about '83 where they started using the 8.8.
Old Sep 28, 2011 | 09:02 AM
ctubutis's Avatar
ctubutis
Show me the VIN
Yes, NumberDummy and usually even I can find this information in the FoMoCo parts catalog.
But I'm going to ask the OP to show me the VIN on that label.
If you're scared somebody is going to be able to hunt you down and kill or maim you - or whatever you might be aftraid of - by showing the VIN of the truck, then hide the last several numbers from us. Those are the Production Sequence Numbers, aka the Serial Number.
Old Sep 28, 2011 | 09:10 AM
jimmy dale's Avatar
jimmy dale
my axel ration was on the ring gear but it was a math problem
24.5 / 9 ---------24,9 divided by 9 is 3.50 gear ratio lol
Old Sep 28, 2011 | 09:27 AM
kedwinh's Avatar
kedwinh
How'd you come up with that?
Old Sep 28, 2011 | 05:16 PM
Junior Junior
I just blocked out the vin because I've seen several other people do it. Figured it was a good idea.
Anyways, here's the VIN, ctubutis: 2FTCF10E3CAA64379.
Old Sep 28, 2011 | 09:03 PM
ctubutis's Avatar
ctubutis
There is normally a space between the 2nd & 3rd characters
Ah, I see.
Well, there is something wrong there, I think it's the 11th character, I'm guessing it should be a C and not an A....
Code:
Pos.
1-3)   2FT = World Manufacturer - Ford Motor of Canada, Ltd, complete vehicle
4)     C - Class C 4001-5,000 pounds GVWR
5-7)   F10 - 80/83 pickup F100 2WD
8)     E - Gasoline-powered 300 cid 6 cyl 1V carb light duty
9)     3 - Check digit, varies
10)    C - Model year 1982
11)    A - Assembly Plant (nothing listed for A, I'm gonna guess C - Ontario Truck Plant)
12-17) A64,379 - Numerical sequence of assembly
Alternatively, the 10th position could be an A but that would make it a Model Year 1980 truck.
In any event, I was mostly interested in the Series (positions 5-7) and the Model Year (10th position) just to verify, because.........
We begin OK, but I'll explain there is generally a space between the 2nd & 3rd digits of your axle code:
Also from the book:
Your code of 07 equates to a Ford-built 2.47:1 ratio, Capacity of 2.8M (not sure what M stands for but I'm gonna guess 2,800 lbs.), used in 1981/82.
OK, now the weird part....
OK, the third digit represents the front axle:
You've got a 5 in that position, and the book says that code in that position was used in 1983 only, and means the truck has power brakes.
This is what caused me to ask you to show me the VIN, I wanted to make sure you had a Model Year 1982 truck.
So, I will write this off as an error in the book (this isn't the only error) but will nevertheless ask NumberDummy to come and verify my findings (I hate it when I post wrong information).
Changing that A to a C (Assembly Plant, 11th position) makes the Ford Fleet VIN decoder (https://www.fleet.ford.com/maintenan...ls/default.asp) happy, but I'm not entirely confident the mistake is there........
In any event, it looks like your rear axle code is 07 which is a 2.47:1 ratio which would explain your gas mileage.
Last edited by ctubutis; Sep 28, 2011 at 09:18 PM. Reason: I mean the Ford Fleet decoder, not the one here on FTE
Old Sep 28, 2011 | 09:08 PM
1983F1503004x4
Wow, that thing is geared like a CAR! No wonder the "hockey puck" tires and gas mileage.
Interesting error.
Old Sep 29, 2011 | 02:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The thing I'm perplexed about is this "075" axle code. I've looked EVERYWHERE except...
In the General Information Section of the 1980/89 Ford Light Truck Parts Catalog, Page 39-Rear Axle Ratio Codes.
075: 07 = Ford 9" Rear Axle / 2.47-1 / non Limited Slip / 2,800 lb. Rear Axle Capacity / 5 = Power Brakes.
Anything else you'd like to know?
Chris: I've decoded over 700 VIN's, Rating/Warranty Plates/Certification Labels for FTE members.
I have yet to see a 3 digit axle code with a space between the two digit rear axle code and the single digit front axle code.
It is defined that way in the general info section of the catalog (notice the circles), but not in the real world, as you can see above.
btw: C = Oakville, Ontario Canada Truck Assembly Plant.
The truck was assembled in Canada, but that doesn't mean it was sold there.
DSO 16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Sep 29, 2011 | 08:07 PM
Junior Junior
2.47!? Yeesh. Better throw in a 2.75 so I can slash that crucial 60-foot time in half!
Thanks for the help, guys. You efforts and time spent on this are greatly appreciated. I'm glad to know I have the most awkwardly geared truck in northeast PA.
Old Sep 29, 2011 | 08:46 PM
philofab's Avatar
philofab
I did a customers 79 Ranchero that had that gear in it.
Built rollerized 400m made 30+mpg with a C6 on the highway.
Old Sep 30, 2011 | 08:45 AM
Junior Junior
30+?! Hell, I'm getting a cheated. Writing an angry letter to Ford's hockey team immediately.
Old Sep 30, 2011 | 01:38 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yeah I only get 21 MPG! What the heck?
Old Sep 30, 2011 | 05:56 PM
kedwinh's Avatar
kedwinh
Yep that's terrible! I get almost 14 MPG
SideWinder4.9l
Jun 22, 2009 12:04 AM
pc_2000
19
Oct 7, 2008 06:28 AM
Bassgetter
Aug 7, 2003 05:52 AM
nzabka
Aug 3, 2003 06:48 PM
Duderoy
Feb 3, 2003 10:37 PM
