Offroad & 4x4
Yep its a Van...
Old Sep 28, 2011 | 07:05 PM
fatdan460's Avatar
fatdan460
dave, is the side door on that a slider or two normal swing out doors? looks like a slider. if it's a slider you'll have to go with more lift or run some super narrow tires as it doesn't take much before you run into door/tire clearance issues.
Old Sep 28, 2011 | 07:48 PM
hav24wheel's Avatar
hav24wheel
Its a slider. I was thinking a 315/75R16. I have these wheels I'm making that are 16x10s that look like a factory wheel.
Josh, how tall is that tire u are talkin about? Altho, I'd have to use stock 7 inch wide wheels for them
Old Sep 28, 2011 | 07:50 PM
hav24wheel's Avatar
hav24wheel
Dam Dan, ur right! There isn't much room there.....
Old Sep 28, 2011 | 07:57 PM
fatdan460's Avatar
fatdan460
sooner or later dave, everyone realizes i'm right
my solution, and one i'm pretty sure you are capable of doing, is some light sheetmetal work. cut and notch the bottom corner of the door and weld it in solid to the van's shell so the door has a relief cut out for tire clearance. does that make sense typed out or no?
Old Sep 28, 2011 | 08:01 PM
hav24wheel's Avatar
hav24wheel
Perfect. That's added to the "to do" list
Now why the **** does it still smell like mouse **** after a good washing out, and all doors open for two days?!
Maybe I missed some... On a + note, the seats don't stink no morez
Old Sep 28, 2011 | 08:23 PM
captain p4's Avatar
captain p4
Mouse nest/poo in the hvac system?
Old Sep 28, 2011 | 08:51 PM
hav24wheel's Avatar
hav24wheel
Mouse poo/nest in the everything.
One on the motor, 3 separate ones in the headlinner, one under each tail light, one in the secondary heater, one under the drivers floor mat, and I'm sure I'll find another in the primary heater once I open that up...
Old Sep 28, 2011 | 09:05 PM
alpha/omega's Avatar
alpha/omega
Ive found the best way to get rid of a rodent infestation is cut off his beer/food supply and point his truck north on I-95.
Old Sep 28, 2011 | 11:46 PM
nobodyspecial's Avatar
nobodyspecial
Dave, those are the same tires I have on my Mountaineer. Unmounted, they measured out at 33.5" and 10.5" wide I run them at 60 PSI. They are load range E, and I have over 10K on them with no noticeable signs of wear.
Old Sep 29, 2011 | 12:03 AM
captain p4's Avatar
captain p4
I hate when he does that
Old Sep 29, 2011 | 11:04 AM
alpha/omega
^^^Well stop eating all the damn cheese out the mouse traps .
Old Oct 1, 2011 | 04:36 PM
hav24wheel's Avatar
hav24wheel
Well, I think I got all the **** cleaned out now.
And with a new fuel pump(major pita) and a new carb it runs alright. Doing plugs wires n all that garbage tonight, than I'll tune it. After that, reinstall the interior
Old Oct 1, 2011 | 04:48 PM
  #28
White 97 xlt's Avatar
White 97 xlt
Back in the day there was a door extender that people got to clear wide tires.. A buddy (Ford Van) had to get one when he changed to wider tires.. Best I remember it just extended the link on the rear of the slider.. I wonder if they are still available..
Old Oct 1, 2011 | 06:24 PM
  #29
hav24wheel's Avatar
hav24wheel
Hey I'm sure it wouldn't be too hard to fabricate one
Old Oct 1, 2011 | 10:42 PM
  #30
alpha/omega
:idea:
Find an old wheelchair lift so you can load your 4wheeler inside
