Possible brake MC issue?
Old Sep 27, 2011 | 12:05 AM
remiskeet's Avatar
remiskeet
I have a 1992 Ranger 4x4 2.3 5spd that I have owned since new (Jan '92). The last few days I've had problems with the front calper "appearing" to be stuck. The brakes overheat on a drive of only 10 miles or so.
Calipers/pads/rotors/wheel bearing were new in Dec 2010. Hardlines and flexhoses (front & rear) were new in July 2011. At that time I vacuum bled all 4 corners ,starting at the right rear,left rear etc.etc.
I cannot retact the piston using a c-clamp,UNLESS I open the bleeder screws. This leads to me to think that the calipers are fine , but something is preventing fluid from returning to the master cylinder.
Any ideas? Does vacuum bleeding, as opposed to pressure bleeding mess up the postion of the master cylinder pistons? Or have I just reached the end of my MC's "service life"?
Thanks in advance for any suggestions
Old Sep 27, 2011 | 03:34 AM
Dan Robertson's Avatar
Dan Robertson
I had a similar problem with one caliper on an old Ford Tempo. It ended up being a faulty brake hose. The rubber deteriorated on the inside and the deteriorated rubber formed a "one way valve". My caliper would release but was much slower than the other side, making the car pull after the brakes had been applied.
Don52M3
Jun 11, 2019 10:01 AM
TO21
May 28, 2015 09:30 AM
DansBBF250
20
Jun 30, 2010 08:45 PM
05sporttrac
Mar 28, 2010 09:47 AM
wildjon300ci
Jun 9, 2002 10:15 PM
