1978 - 1996 Big Bronco
Getting Ready to Go Big
Old Sep 26, 2011 | 03:40 PM
Bronco308's Avatar
Bronco308
I just scored a 1979 4X4 E250 van frame (no body), 460, C6, Dana (?) axle's, runs. Should I just put the 460 in my '83 Bronco (Dana 44 IFS/Ford 9 Rear) or do the whole axle swap, too? The front axle on the van chassis is coil sprung, not leaf, which is what I've seen on most 3/4 ton and up trucks. Does anyone have any experience with the coil sprung E250 Dana front axle swap?
Thanks in advance.
Old Sep 26, 2011 | 04:47 PM
andym's Avatar
andym
It depends on what front axle they used. Do you know what axles the van chassis has?
As for whether you should transplant the engine or the whole drivetrain, we are going to need a ton more information about your bronco to be able to offer an opinion.
Old Sep 26, 2011 | 07:09 PM
Edgethis's Avatar
Edgethis
Well most likely you'll need the transmission too as yours should have the small block bellhousing.
But as Andym said, post up your Bronco's info and more info on teh Van.
Old Sep 26, 2011 | 09:18 PM
Encho's Avatar
Encho
The Southernmost Mod
Yeah, time to create a signature, to stop the guessing game .
Old Sep 27, 2011 | 09:50 AM
Kemicalburns's Avatar
Kemicalburns
the van will more then likely be a 3/4 ton D44. someone over on FSB had done this very swap using a van front end. it was no more plug and play then doing a regular SAS honestly and i believe he gained less articulation and what not by going this route.
I say throw a cage, seats and some sort of roof and wheel it as is. leave your bronco as is.
Old Sep 27, 2011 | 10:24 AM
andym's Avatar
andym
A van chassis with a roll cage and seats for 15 would make a sweet trail rig.
Old Oct 1, 2011 | 09:32 PM
Bronco308's Avatar
Bronco308
roll cage on the van chassis sounds pretty intriguing, i'll have to think on it. as for my bronco, it's has a blown 351w, d44 ifs, ford 9 in the rear, 3.50's , limited slips in both, NP 208. the 3/4 ton e250 has a solid d44, and a dana 70 in the back, 3.73's, the back is ls, can't tell on the front as the tag is missing. the 460 itself already has the saggy-gnaw ps pump on it, and of course the tranny will have to be swapped, too. 460 also has a NP 205 transfer case. thanks for the help, guys, i appreciate it.
Old Oct 1, 2011 | 09:42 PM
Edgethis's Avatar
Edgethis
Isn't an NP 208 the Fulltime transfer case? Didn't think they had full-time/AWD Broncos. Your Bronco sounds nice, where are the pictures?
Edit: My bad, I was thinking of the NP 203.
rebar13
WTB - Parts & other
Feb 14, 2015 04:46 PM
wvmudder
Jan 31, 2005 08:20 PM
rustang
May 3, 2002 11:45 AM
brychar
Jan 21, 2001 10:24 AM
