Front end problem
Old Sep 26, 2011 | 08:27 AM
jgilrfr's Avatar
jgilrfr
Front end problem
I am getting a banging noise when I turn my wheels.I have jacked up the front,put a bar under the tires and lifted and have no play in the ball joints.I did notice play in the passenger u joint and changed it.While changing it I had both wheels off the ground and no more noise.I turned the wheels by hand and had no problems.I dont have any play in any of the tie rod ends.It seems as if something is binding but I cant figure out what.I still have the binding after fixing the u joint.I tried jacking up one side and turning the wheels,then the other and it is the same,still binding.Any help on what to do from here is appreciated. John
Old Sep 26, 2011 | 09:07 AM
86fu50's Avatar
86fu50
It sounds like you have one or both hubs locked. when i first rebuilt my hubs I put the spring on the wrong side of the gear. so the hubs were always locked. It made a banging noise while i was turning.
Old Sep 26, 2011 | 09:35 AM
jgilrfr's Avatar
jgilrfr
thanks for replying,i checked and they are off ,I found I have a cracked hu on the passenger side and removed it and turned the wheels,still binds,the noise seems to come from the passenger side
Old Sep 26, 2011 | 05:58 PM
jgilrfr's Avatar
jgilrfr
just for fun,i disconnected the sway bar to see if that helped,it didnt,then i tried to disconnect the tie rod at the passenger side and the nut is frozen and the bolt is spinning in the tie rod end,does this have to be cut out somehow?
Old Sep 26, 2011 | 06:22 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Is your tie rod end loose in the steering arm (up and down)? I had a clunking noise a while back and I crawled under the truck to check and found a gap on both of my tie rod ends. One had more play than the other. I know the nuts hadn't loosened on their own because the cotter pins were in place still. I removed the pin and nut and the tie rod lifted right out quite easily.
So, I pondered the situation and decided it just might be time to replace the whole front steering assembly since they are original parts with almost 280k miles. I had to order the parts and it was going to take about a week to arrive so I decided to put some grade 8 washers in there so I can use my truck while waiting for UPS to arrive. After I did this, the clunking noise during turns went away and the steering still felt nice and solid. I went to the alignment shop to have them check it out (since I paid for a lifetime alignment) and they said what I did will work and the tie rods were nice and tight and the alignment was within spec.
So, long story short, I've been driving like this for the summer and I plan on changing out the parts later this fall when it cools off some. So, you might be able to get away with a similar fix (if you can get your nut loose...). Do you have an impact gun? That might get the nut off...
Old Sep 26, 2011 | 06:36 PM
jgilrfr's Avatar
jgilrfr
i have an air gun but the spindle the nut goes on is spinning also
Old Sep 27, 2011 | 02:03 AM
carltonwebb's Avatar
carltonwebb
Are the bushings worn on the stabilizer for the steering?
Old Sep 27, 2011 | 07:57 AM
jgilrfr's Avatar
jgilrfr
i dont have a steering stabilizer,i bought the truck with 25000 miles(has 215000 now) and it didnt have one and i never added one,probably should though
afonda
19
Dec 20, 2017 09:20 AM
jtug69
Jan 23, 2015 07:32 PM
flip1950
May 27, 2010 07:09 AM
Brian0445
Apr 21, 2007 07:34 AM
kenjan61
Nov 17, 2005 12:27 PM
