Sponsored by: Real Truck
front end clunking when turning
Old Jan 23, 2015 | 07:28 PM
jtug69's Avatar
jtug69
Have an 03 f250 6.0L and the tie rod from pitman arm moves easily and there isn't a steering stabilizer, noise got worse after I put new tires on front but it's a loud clunk that I can feel. I've replaced the sway bar bushings and end links. Would the worn tired rod make that noise or would it be ball joints?
Old Jan 23, 2015 | 07:32 PM
SuperDutyScaler's Avatar
SuperDutyScaler
You already know you have a loose tie rode so thats your answer. There should be zero play in the rod ends fix it ASAP and yes it will cause bangs and clunks
iPhone from IB AutoGroup
jrlaidle
Jul 25, 2017 06:59 PM
moomba2002
15
Apr 21, 2014 05:16 AM
bigdaddyII
13
Feb 15, 2006 08:40 AM
jaystersj
Dec 16, 2004 11:23 PM
