Sponsored by: Real Truck
Cruise control self test question
Old Aug 31, 2013 | 08:50 PM
kefrko's Avatar
kefrko
Originally Posted by ckutter
2001 F250 SD 7.3 PSD
Was doing a trailer towing road trip too and from Montana. On the way back the cruise control stopped working.
Checked fuse #28. Looked fine.
Attempted to do a self test on the cruise control. Holding the OFF button did nothing. Never went into diagnostic mode.
Button ? A different fuse?
Hey CKUTTER I know this is an old thread but I was just wondering if you were able to fix it and if so what the problem was. I am in a similar boat. I have a 2000 f350 7.3. I was working on it today at my friends house and replaced the stock exhaust with a 4" turbo back and I did the "Gooch's coolant flush" procedure. On the way home I tried to use the cruise control and nothing. after some research I came across the diagnostic test and tried that but the light wouldnt come on even to enter the test mode. I was planning on checking the cruise control switch on the master cylinder next. Brake lights work, horn works, etc.
Old Oct 10, 2013 | 01:46 AM
Enduroman's Avatar
Enduroman
Any new wisdom on this??? Been reading countless threads about this.
My '03 F-350 6.0 Cruise Control was intermittent for a while and since trying the Self Test procedure, its now completely dead. When it was intermittent, it would often drop off line for me when I engaged it, as if trying to add power as the truck decelerated, then quit altogether, not to come back.
Self test did not work. Never saw any flashes at all.
Horn works. Fuse fine.
Auto transmission.
Sometimes have trouble getting trailer brakes to operate. (maybe related?)
Replaced Brake Pedal switch last year, when I couldn't get the transmission out of Park. (related?)
Any ideas for troubleshooting are appreciated. Thanks.
Old Oct 10, 2013 | 01:41 PM
Enduroman's Avatar
Enduroman
Hmmm. Just tried doing an instrument cluster test by pressing the Trip Meter (Select/Reset) button while turning the key on. (Park brake on) It entered a test mode where all kinds of parameters were shown by pressing the button repeatedly but what I think is relevant is that the cruise control light never came on when 'bulb' was indicated, and all other lights were illuminated.
Old Oct 10, 2013 | 06:11 PM
kefrko's Avatar
kefrko
Auto transmission.
Just to follow up. Mine turned out to be a leaking cruise control switch that is mounted on the master cylinder. I had read that can be a problem and you can usually see it leaking or you can remove it and look for brake fluid leaking into it. Its a recall item on my truck 2000 f350 CC 7.3L and it maybe on yours as well. I took it down to the dealer and gave them the VIN and sure enough it hadnt been done yet so it was fixed for free. so far so good it has been working well. hope this helps and its something as easy as mine.
Old Oct 10, 2013 | 08:13 PM
Yahiko's Avatar
Yahiko
FTE Remembers
That was the reason for the fires that resulted in the recall. The switch would
stay in the closed and over heat the small wires. The fix involved a small
harness that has a set of fuses in it. If you can find the harness for your
model I would get it and install.
Sean
Old Oct 11, 2013 | 12:46 AM
Enduroman's Avatar
Enduroman
Thanks for the follow ups. Looked for recalls online with my VIN and no such luck. Also brought it to mechanic who hooked it up to his computer. No codes, but he did find that the parking brake switch was not working. I hadn't noticed. Either way, didn't get the Cruise Self Test to work.
Hate to - but might have to just start replacing components till it works. Probably start with the switch/harness on the master cylinder - depending on price. I can't live without cruise control.
Old Oct 11, 2013 | 06:18 AM
Budman1962's Avatar
Budman1962
If you figure it out please let us know what the problem was. There has been lots of threads on here about dead cruise controls. Mine has been dead for a year or so. Fuses are fine.
Old Oct 15, 2013 | 01:04 PM
Enduroman's Avatar
Enduroman
Count on it. I too have read countless threads about Cruise Control problems that appear to have remained unsolved. Wish more folks would come back and close up their threads...
Old Oct 15, 2013 | 01:55 PM
Gangley's Avatar
Gangley
Its the cruise control deactivation switch. The kapton seal within the switch can deteriorate and allow caustic brake fluid into the switch. The result is a slurry of copper that was degraded from the switch terminals. The degraded switch terminals no longer make contact in their normal position and therefore the circut cannot be completed. Get a cruise control deactivation switch from a buddy or a local auto supply store and install it. Check the function of the switch to verify its working.
Old Oct 18, 2013 | 12:46 AM
Enduroman's Avatar
Enduroman
Yes, I've been reading about that cruise control deactivation switch (aka brake pressure switch??) all over the place and how it gets covered in brake fluid and deteriorates, and I resisted that as a solution to my problem because my switch and harness look almost like new. To eliminate that as a problem beyond any doubt (and because Gangley sounded so certain) I thought I'd fiddle with it a bit, before stopping at the dealer this morning to press them for info about possible recalls (there are none for mine) and part numbers. Lo and behold the damn thing came back to life and worked perfectly on the way to the dealer. So I just cleaned up the contacts on the harness with a dental pick, put some electrical grease on it, and its good as new. (BTW, still can't get the cruise control self test to work on mine - never has. Maybe not programmed for my model)
Old Oct 18, 2013 | 06:29 AM
Budman1962's Avatar
Budman1962
Thanks for the info. Mine was replaced with the recall so I didn't think it would be the brake switch. I'll definitely look into it. I hate not having cruise control.
Old Oct 18, 2013 | 07:25 AM
terrym041's Avatar
terrym041
I have an issue like this when I do the self test I get 1 flash when I turn the key on holding the off button then 1 flash when I press the on button but I get no flash when I press the resume or set/accell buttons any ideas? 2003 f250 5.4l manual tranny
Old Oct 18, 2013 | 02:58 PM
  #28
terrym041's Avatar
terrym041
I fixed mine I think im the only person ever lol mine would do the diagnostic test giving me the two light error after some digging i tore the clutch pedal switch out and there are two springs in there that were busted up not allowing the switch to go back to pedal up position i moved it manually and everything worked after i installed a new switch 30 bucks later to think i havent had cruise for a year over this thank god it works again
Old Oct 23, 2013 | 09:07 AM
  #29
fire109's Avatar
fire109
I am a new member and have a problem with my cruise control on my 2003 f250. I changed the brake pressure switch located at the bottom of the master cylinder after reading on line, it is a back up system in case your brake lights fail. How ever that was not the problem. If I find out I will let you know.
Old Mar 11, 2014 | 06:47 PM
  #30
milenko634's Avatar
milenko634
Terrym041 did your truck start without you having to depress the clutch pedal before you replaced the switch. I am having CC problems as well, but had ruled out the clutch pedal switch since my truck will not start without me pushing the clutch pedal down.
