96 Reg Cab to SuperCab Conversion
Old Apr 7, 2003 | 06:53 AM
72CutlassS's Avatar
72CutlassS
Question 96 Reg Cab to SuperCab Conversion
Has anyone ever done a conversion (I'm sure someone has) from regular cab to Supercab? I have a 96 RC 4X4 Shortbed that I really want to keep for a long time, but I really need the extra room of an extended cab. I've priced a cab (w/o doors) at $600 and I really can't see that it should be real tough to stretch the frame. I have a buddy who is a steel fabricator that should have no trouble doing it. After that it should just be a matter of extending the fuel lines and buying an SC drive shaft. (Is that one piece or two?)
My neighbor has a 95 SC that I should be able to use for reference.
I just wanted to get a feel for what you guys thought and if anyone has done it.
Thanks
Old Apr 7, 2003 | 10:54 AM
MustangGT221's Avatar
MustangGT221
It's a good sized project. If the truck is 4wd the D/S a 1 piece, if it's 2wd it has a two piece. I suggest you get a ford dealership manual, I got one and it's about 3" thick, good book. I got it off ebay, mine comes from 95. You can obviously stretch the frame safely (limos) so I don't see why not. I don't see any major complications. Taking the cab off is going to be a pain in the butt, but it's worth it right!
Old Apr 7, 2003 | 07:09 PM
jommer's Avatar
jommer
You need to remember that there's more to it than the fuel lines. There's also brake lines, tail light wiring, exhaust pipes, and emergency brake cables. Also, be aware of cab and bed clearances. I believe the minimum clearance between the rear of the cab and the front of the bed is 21 mm. The Ford manual is definitely something you'll need. Even a chilton's manual has this info.
Good Luck!
Old Apr 8, 2003 | 12:17 AM
Ryan50hrl's Avatar
Ryan50hrl
i think it might be easier to find a cheap 2wd extended cab and reuse that frame to do your buildup...that way everything is there
RedTonka
Jan 19, 2015 12:30 PM
lcgeek
24
Oct 1, 2014 08:32 PM
ahnjoan
Jul 17, 2013 02:46 PM
station29
Apr 1, 2013 07:53 AM
TopThis8899
28
Mar 20, 2007 11:14 PM
