Trans temp
Old Sep 25, 2011 | 04:00 PM
jwill8957's Avatar
jwill8957
Trans temp
Ive never had a trarns temp guage before so I dont relly know what to look for but for normal driving is this high? It went up to 199
Old Sep 26, 2011 | 06:38 AM
maytag906's Avatar
maytag906
That's about right.
Old Sep 26, 2011 | 08:37 AM
Pale Screw's Avatar
Pale Screw
Yep, it's normal. Take a look at your analog gauge in the upper right corner. It's about mid range.
Old Sep 26, 2011 | 01:15 PM
cdmm151's Avatar
cdmm151
Don't know if it is normal but that's what mine is.
Old Sep 26, 2011 | 01:27 PM
TheWhiteBeast's Avatar
TheWhiteBeast
The tranny temp gauges first came out on the super duties. One of the main reasons is that people were putting their trucks in neutral while on a downhill and consequently overheating their transmissions...plus that is extra wear on your brakes which is just dumb.
Old Sep 27, 2011 | 06:19 AM
jwill8957's Avatar
jwill8957
Alright thanks i just wasnt sure cause whwn i start out the analog gauge is at the left and goes up as i drive. The digital guage seems to start out aroubd 120 and jumps arpund quite a bit
Old Sep 27, 2011 | 06:29 AM
meborder's Avatar
meborder
I wasn't aware that bumping to neutral down a hill would heat the trans up. Good to know i suppose.
As for it being a dumb thing to do, perhaps, but not as dumb as you make it out to be.
If one thinks that they are saving some wear and tear on the motor and trans, then it is not so dumb. Sure it wears the brakes, but who cares? Brakes are cheap. Transmissions and engines are very expensive.
I do not downshif my manual transmission vehicles as i decelerate. And if I do wish to use the engine for braking, I will double clutch and rev the engine to avoid wearing on the synchros. Every downshift makes the synchros work to match the gears unless you can match the speed of the input shaft to the gears.
I see people chase gears while decelerating, or using the engine for braking as normal practice and to me that is just dumb. Clutches are expensive, synchros are expensive ... brakes are cheap.
just my thoughts on that ...
but i'm glad to know that bumping to neutral is bad karma ... something I did not know.
Old Sep 27, 2011 | 07:30 AM
TheWhiteBeast
Manual trannies are a whole different beast. The two are lubricated in very different ways. Manual transmissions have passive lubrication where the gears just run through the fluid, but an auto has a pump. There are a few exceptions to this though.
Old Sep 27, 2011 | 08:49 AM
Onus's Avatar
Onus
I down shift my e4od all the time in my idi on this one hill near home. Slows it down good. Also have a huge tranny cooler and the fluid is pink and good. I'd much rather be driving a manual but i'll take what i can get. The new manual shift cars are funny drove a Mazda 6 and had fun downshifting to a stop.
Old Sep 27, 2011 | 10:13 AM
TheWhiteBeast
There's no problem with down/upshifting. It's neutral while at speed that will burn up a tranny due to lack of lubrication. Get a shift kit for your truck, works wonders. Remember International Scouts with that garbage Chrysler tranny? You pretty much had to manually shift them. Unlike a manual tranny, an auto will go into the gear selected when it is good and ready. I also enjoy a good pizza.
coachvassar
2009 - 2014 F150
May 16, 2017 11:03 PM
kx125str99
19
Dec 20, 2016 07:51 PM
equine hauler
Jul 22, 2009 12:22 AM
yamaguy
Jul 15, 2007 09:00 PM
JRB
Jan 2, 2005 08:54 PM
