Cleaned EGR valve
Old Sep 24, 2011 | 04:37 PM
JonArmy's Avatar
JonArmy
Cleaned EGR valve
Well this morning had time to clean my EGR valve, it wasn't as bad as I've seen pictures but it had built up enough were it needed cleaning. I also cleaned the piping were the valve goes, took some time but got it as clean as possible. The only issue I had was after installing the valve back on and connecting the wires I went to start the truck and it hessitated enough that I turned it off and let it settle for a moment. When I tried again it started back up just fine. My question would be was it to clean or was there some residule carb cleaner that I used to clean the valve and pipe. With that hesitation did it hurt anything or was it just adjusting to the clean valve/pipe?
Old Sep 24, 2011 | 05:02 PM
Snuggyworm's Avatar
Snuggyworm
u probably had some air in there. maybe a little soot from a spot u missed. if everything runs right again, i'd assume u did a great job.
Old Sep 24, 2011 | 05:12 PM
JonArmy's Avatar
JonArmy
Ya it ran fine after I got it started, the only problem I really had was halfway through the cleaning it started to down pour rain, I was using a baby food jar to soak the valve, I just stuck that under the truck and covered the top while I worked and got soaked on the piping.
Old Sep 24, 2011 | 06:31 PM
Snuggyworm's Avatar
Snuggyworm
it aint tat critical as long as it's not swimming underwater. if ur paranoid like i am, maybe u could pull it out, and use a can of air blower and blow thru the holes. jus to make sure it's completely dry. remember to unplug ur egr valve first. then have a beer! too bad the margarita hula girls dun come wif the beer. lol.
davlan88
Nov 20, 2017 04:14 PM
clevelandtundra
Mar 11, 2013 10:33 AM
Chrisv2285
Jul 22, 2011 02:03 PM
UGA33
Mar 17, 2009 02:49 PM
Northriver
Feb 11, 2009 05:13 PM
