93' ford 460 choking problem..
Old Sep 24, 2011 | 04:30 PM
dodgdatona's Avatar
dodgdatona
lately my 93 f350 with the 460 starting running rich and getting pretty fummy outside. I ran the codes and the only one that came up was the throttle position sensor. I changed that, air by pass valve and plugs/wires with no luck still. I scaned it again and nothing will come up, but is it lacking on power and still running rich.
It will start with no problems and idle.
I did notice though that the rould canister with the exhaust hose that connects to it on the passenger side(behind the battery) doesnt blow air out of the side of it like my other trucks do.
Anything else i can try to correct this?
Old Sep 25, 2011 | 10:35 AM
subford's Avatar
subford
Pull the vacuum hose off the Fuel Pressure Regulator (FPR) and turn the key on and off with a cold engine. If any fuel comes out of the nipple on top of the FPR it is bad.
Old Sep 26, 2011 | 02:01 PM
dodgdatona's Avatar
dodgdatona
this may sound like a dumb question, but where is the fuel pressure regulator at on the truck?
Also, i have notice that the motor is pussing oil into my air cleaner box and out onto the fender quite alot now too. I cleaned out the pvc valve with air as it was alittle cruddy inside of it.
Old Sep 26, 2011 | 02:24 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » Fuel Pressure Regulator (FPR) Click on this link, shows what the FPR looks like and describes where it is.
I would fit a new PCV valve and clean out the pipes to it.
Old Sep 26, 2011 | 02:36 PM
TheWhiteBeast's Avatar
TheWhiteBeast
Oil in your air cleaner box means bad valve stem seals more than likely as the hose goes from your valve cover to your air box. Pull the hose off your valve cover and tell me if you see smoke. You shouldn't see anything but maybe a puff. If it is continuous, definitely a valve stem or bad rings causing some major blow by if you are seeing motor oil in your air cleaner box.
Old Sep 26, 2011 | 02:38 PM
TheWhiteBeast
But you also just may need to get an oil seperator as many people that own mustangs have gotten that goes between the PCV and the air box.
Old Sep 26, 2011 | 05:10 PM
dodgdatona's Avatar
dodgdatona
should i start out doing a compression check first or pull the pvc hose and look for smoke?
Old Sep 26, 2011 | 06:27 PM
TheWhiteBeast
Easiest thing first
F250_HD_Crew
44
Jan 30, 2015 10:11 AM
dodgdatona
Jan 31, 2012 08:32 PM
Msp541
18
Feb 1, 2007 09:13 PM
sljim
Apr 13, 2003 04:43 PM
a63unibody
Mar 30, 2001 07:14 PM
