Transmission acting up
My transmission has started acting weird. When it's cold it seems to be not as bad. First thing is when I put it in reverse it hesitates for a few seconds then goes into gear. Second it will drive great then just out of no where start shifting very hard then go back to shifting smooth again. Third when pulling a load it won't always start in 1st gear when you come to a complete stop sometimes it tries to start off in 4th. Any ideas would be greatly appreciated
I have about 4k more miles than you on the same combo... '05 6.0. Never experienced any of the last issues you mentioned. But the shifting from D -> R does hesitate as you mentioned...to the point it will almost make the engine lope sometimes. Mine was flushed with full filter change about 20k miles ago. Did it before then, and still does it...with no codes being spit out. Depending on which tune I run, shift firmness varies, but stock it's like butter.
Check for codes first, then if it's not toasted - I would change the transmission fluid and filter. For all you know, it has the original fluid from the factory with 139,000 miles on it.
