Ross, is correct. The front part of the '52 frame is a bit different in the front engine mounting area. Other than that the sheet metal will work. I have '48-50 sheet metal on my '51 F-4.
Some fabrication will be required, I believe. Look here: https://www.ford-trucks.com/forums/1...l#post11357016
Hard to say, on the one hand the rubber mounts are unique for '52, even for the V8's. Maybe you just need to use the '52 biscuits.
