F1 and F3 Frames
Old Oct 25, 2010 | 08:07 AM
RRHD's Avatar
RRHD
F1 and F3 Frames
Question from Canada - Is the 48 -52 F1 frame and the F3 frame the same? If not what are the differences? Help
Truckin Ronnie
RRHD
51 F1
92 FLHTC
06 Ridgeline
Old Oct 25, 2010 | 08:26 AM
4tl8ford's Avatar
4tl8ford
The f-3 frames are longer (They can be shortened, but need to be cut in two places) and the frame rails are taller.
Old Oct 25, 2010 | 09:31 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Like Penn Dick said, longer wheelbase at 122" for F-2/F-3 vs. 114" for F-1. The F-1 rails measure 5.92" tall x 2.25" wide x 0.15" thick. The F-2/F-3 are 6.00" x 2.25" x 0.19". The F-2/F-3 also have a bigger transmission cross member. The F-1 has four cross members while the F-2/F-3 has six. Stu
Old Oct 25, 2010 | 05:38 PM
RRHD's Avatar
RRHD
Thanks for the quick answers.It helps alot! The front of my F1 frame has been cut and also bent by the PO (forward of the engine cross member), I was thinking of welding in a section of an available F3 frame. Any thoughts?
RRHD
Old Oct 25, 2010 | 06:43 PM
jim collins's Avatar
jim collins
I would check the f-3 frame to see if it was square and not twisted. Then shorten it to fit the cab and box to .If the f-1 frame has been cut off in front it may have been wrecked and damaged out of square. It may be less work to use the f-3 frame. It's been done a number of times here, maybe one of the members that have done it will help guide you.
Old Oct 25, 2010 | 07:48 PM
RRHD's Avatar
RRHD
Thanks Jim, the F3 frame is not complete it has been cut off (why I don't know) just aft of the engine mount. I have only seen pictures, look straight. Thought I could cut off what I need and weld it on? going to be a daily driver not a show truck.
RRHD
Old Oct 25, 2010 | 08:20 PM
jim collins
RRHD
Sorry i misunderstood you, i thought the f-1 frame was cut off and the f-3 was a good one. So I can't help you , good luck , jim
Old Oct 25, 2010 | 11:06 PM
4tl8ford's Avatar
4tl8ford
If possible keep the welds outside of the spring mount holes - in front of/in rear of.
Old Oct 26, 2010 | 12:49 PM
gearhead1952's Avatar
gearhead1952
The dimensions of the two frames forward of the cab are the same but I believe the f2/f3 frames are a tad thicker. I've cut up quite a few but never actually measured the two.
Old Oct 27, 2010 | 12:31 PM
RRHD's Avatar
RRHD
Going to but the F3 frame that is available to me, althought it is not a "whole" frame will get just the part I need. Will let you all know haow it turns out
RRHD
leafs_11
Feb 13, 2017 03:19 PM
Hughmullersa
Mar 16, 2016 06:36 PM
brooksdw
Dec 1, 2015 02:02 AM
Kalve
Jun 7, 2011 09:24 AM
Brain's 97 Diesel
Apr 13, 2010 01:28 PM
