Interior lights not working.
Old Sep 22, 2011 | 06:08 PM
2006powerstroke90's Avatar
2006powerstroke90
I checked fuses, as stated in other threads...but when I open my doors the lights will not come on, and I am not sure if there are lights on the door behind that red piece, when I use the dimmer switch to try and turn them on they still wont go on...I hear a click but nothing...
They only go on if I hit the switch on the light itself...
It kinda make it hard for my girl friend to put her seat belt on when she get in LOL
Any advice or what to check?
Thanks
Old Sep 22, 2011 | 06:15 PM
BLADE35's Avatar
BLADE35
Say it isnt so Tyler
could it be something with the running lights you hooked up the other day
Very Sharp I might add
same issue at All 4 doors
I had the opposite issue I couldnt get em to shut off little WD-40 on the door lock mechanism not the key part either worked Great but was the opposite of what you have
Old Sep 22, 2011 | 06:21 PM
2006powerstroke90
LOL, I know
It was like this since the day I bought the truck, I have always lived with it.
I have started with this OCD problem, I have been fixing every little thing with it.
Thanks by the way...
Old Sep 22, 2011 | 06:39 PM
cobra11's Avatar
cobra11
did you check the wires going to the light switch or it may be the switch itself also check thr gound wire i hope this helps
Old Sep 23, 2011 | 12:28 AM
built tough's Avatar
built tough
mines the same way the back seat light doesnt turn on only the fronts do when i open the door
Old Sep 23, 2011 | 06:33 AM
1BigBo's Avatar
1BigBo
Mine was doing the same thing I found there is a lighting relay built into the insterment cluster. I found a cluster at the junk yard for 50 bucks and all is good
LillJunior
2009 - 2014 F150
Feb 1, 2018 05:40 AM
GreaseMonky
Feb 28, 2011 04:49 PM
priester68
Electrical Systems/Wiring
Jun 13, 2009 10:12 PM
micmopar
Mar 29, 2009 07:27 PM
zoomx2
Aug 28, 2004 01:04 AM
