Throttle Position Sensor
Old Sep 22, 2011 | 04:47 PM
Larry00663's Avatar
Larry00663
Trailering
Recently I have had problems starting my truck. It would start but would not come up to idle. When I pressed on the accellerator, it would die.
I had a mechanic friend check it out and unplugged the sensor, turned the ignition switch, then plugged the connector to the sensor, and it started. I drove for several miles without any problems. Since then I have had to reset the sensor on several occasions. I took it to a dealer and had the computer connected. It showed several codes which included the Throttle Position Sensor. I was told that it would be two weeks before they could check it out, as they were that far behind.
I purchased a new sensor and installed it myself. The truck started three times, then I had to unplug the sensor and wait for sometime before it would start.
Anyone have any suggestions as to what I need to do?
2007, F250 Super Duty, 6.0 Diesel
Old Sep 22, 2011 | 04:50 PM
npccpartsman's Avatar
npccpartsman
If you have the adjustable pedals check the wiring harness for chaffing. It's a known problem.
Also, if you have a list of diagnostic codes please post them up. It's possible you have multiple issues that don't include the TPS.
Old Sep 22, 2011 | 05:26 PM
BLADE35's Avatar
BLADE35
ans welcome to FTE
stick around and learn about your truck great tech folder at the top of the page
Old Sep 22, 2011 | 07:15 PM
Larry00663's Avatar
Larry00663
Trailering
I don't have adjustable pedals. The dealer did not give me the codes. I will have to get them from another dealer.
Old Sep 22, 2011 | 07:46 PM
BLADE35's Avatar
BLADE35
aUTOZONE
Oreilys can read codes
Sethro84
Sep 6, 2018 07:46 AM
vintagequest
Jan 20, 2016 05:02 AM
monstermadness
26
Jun 24, 2011 10:05 PM
JMC302
23
Jul 28, 2010 12:36 PM
rickye
1978 - 1996 Big Bronco
Jul 27, 2004 10:24 AM
